Anyone heard of this before?
I took my Cobalt to the dealership to get looked at since I have a warranty for another 3k miles. I originally wanted them to look at the ticking in my engine as I thought possibly a lifter or whatever. I had a warranty, might as well use it before it runs out.
They called me back and told me my belt tensioner was causing the ticking, and that it wasn't covered under my extended warranty, conveniently. But more so, has anyone heard of their belt tensioner causing a ticking that goes away when it warms up?
Are you sure they didn't mean the timing chain tensioner ? I haven't heard of people having trouble with the engine belt tensioner much but the timing chain tensioner is a known problem that has been threw 3 design changes in the last 4 years .
My problem was the belt tensioner making the belt tick.
The tensioner sat weird, and made the belt bend in a abnormal way and made a lash/tick every time a certain part of the belt came around.
Replaced tensioner and belt and had no problems.
You could definitely tell if the car is running with the hood popped and just listen in the general area of the belt tensioner and belt and see if that's your problem or not.
The only reason why I could see the belt tensioner, was when I was replacing my supercharger coupler I had my wife push down on the tensioner with a crowbar while I slipped the belt on the supercharger and screwed the 4 bolts down...she slipped and broke a tiny piece of the plastic tensioner off.
I was going to get a ZZP Stage 3 kit anyway so I can replace the tensioner then.
i had a tick b4. found out my belt was bad>> https://www.cobaltss.net/forums/prob...ssible-252548/ after changing the belt and cleaning all pulleys the sound went away!
But these are cobalts...
Are you sure he didnt mean TIMING CHAIN tensioner? I hear that causes ticking on the LSJs And that SHOULD be part of the powertrain warranty. I dont see why it would not be covered.
a week after i put my stage 2 kit on my belt tensioner went bad. i brought it in with the zzp pulley and all still on the blower. they replaced it... under warranty lmao. is this original warranty? or aftermarket warranty?
Mine chatters/rattles very badly on startup, been told it is normal 5 times by dealers. Latest response was a bad belt tensioner and worn belt. Keep in mind the car had about 54k on the clock, belt was still new and had barely any wear. I changed it out and the tensioner, started the motor without them even on the car....what do ya know, still rattled like hell.
NO dealer will help, I tried fighting customer service, no luck. SEE YA LATER GM, my family and grandparents worked for AC Delco, Delphi, and GM.
For the powertrain warranty, belt tensioners are not included in coverage as your dealership advised. Timing gears, the timing chain, and the timing cover are. Timing belts are covered until the first scheduled maintenance interval.
Hope this helps,
Sarah
GM Customer Service
Thank you for your post, leemanfor,
Hope this helps,
Sarah
GM Customer Service
Hope this helps,
Sarah
GM Customer Service
to the OP, the belt tensioner is not a lubricated part and wont be covered on the 100k mile warranty. but the good news is the tensioner is a cheap part and not difficult to put in. just do it yourself or take it to a local shop. even at a local shop you're going to pay half of what the dealership would charge you anyway. i would never take anything to the dealership to get fixed unless i know for a fact its covered under warranty. but if you do, make sure you tell them before hand not to install anything without your permission. otherwise, they'll just do whatever they want and send you the bill.
how many miles do you have on your car? if its less than 36k then thats why; you have bumper to bumper. if not, then you happened to find a dealership that is willing to work with you and not $^*& you over and you're extremely lucky lol.
@06 SS ALL DAY:
I’m glad that you were assisted in this way! I was basing my response off of the GM Policies and Procedures Manual, which did not include the tensioner as a part of the powertrain warranty.
@leemanfor:
Hope that the resolution you decided upon solves the concern you’ve been having!
Best,
Sarah
GM Customer Service
@leemanfor:
Best,
Sarah
GM Customer Service
@06 SS ALL DAY:
Im glad that you were assisted in this way! I was basing my response off of the GM Policies and Procedures Manual, which did not include the tensioner as a part of the powertrain warranty.
@leemanfor:
Hope that the resolution you decided upon solves the concern youve been having!
Best,
Sarah
GM Customer Service
@leemanfor:
Best,
Sarah
GM Customer Service
WHY would the timing chain tensioner NOT be part of the powertrain warranty??
It's part of the engine. Thats like saying that the #2 intake valve springs are not part
of the warranty? I realise you didn't make up the GM Policies and Procedures, but
that policy sounds rediculous. No offence intended to you.
Sarah,
Dealer tried blaming it on the belt tensioner, and it is 100% fine and belt is basically new still. But put a new belt and tensioner on and noise was still there. Hopefully the motor just blows up under warranty.
She meant the belt tensioner. The timing chain/components are...at least from my understanding. I'm in the same boat you are...
Coverage Code P/P1 see following
Applicable To U.S. Powertrain Warranty
P - Passenger Car and LD Truck Powertrain Components- 5 years/100,00 miles
P1 - Passenger Car and LD Truck Powertrain Components that require maintenance- 5 years/ 100,000 without interruption if maintenance was performed in accordance with the GM Maintenance Schedule
J0791 Tensioner, Timing Chain -- Replace *P
