Back doors won't unlock
This is new, went to go someplace with my daughter and I was going to sit in the back. Neither rear door would unlock by pulling up on the knob (manual locks). The knob does comes up. So, is there a way to unlock the doors so I can take the panel off to see what happened? Very odd it happened to both.
06 LS.
06 LS.
Well if they are closed and cant be opened you should try and remove the rear bottom seat portion to give you room to remove the panel but not sure how much room that will give you
Could be sticking. Spray some silicon lube down the lock hole. As for the panel, it's just clips. If you have a clip pry bar, that will make life a lot easier. A butter knife works as well.
I remember a long time ago that when I had a sedan, a buddy of mine got the buckle lodged in the door jam, and we were unable to open the door at all. If I remember it correctly, I had to remove the door itself from the bolts inside the driver door jam.
