Back on the road. well almost... HELP
alright my car is at the shop right now where they replaced a piston and rebuilt the head because i dropped a valve a few months ago. car is all back together again oil and coolant filled. it turned over and the engine runs but heres the problem. the heat and a/c do not work and all dashboard controls do not work. have any of you ran into this problem rebuilding an lnf, what could it be?
Dashboard makes me say BCM problem.
Perhaps there's a harness or something that they had to disconnect and never reconnected it?
Last edited by alleycat58; Jun 29, 2011 at 12:50 PM. Reason: Automerged Doublepost
Check relay and fuses under the hood.
Crank/run relay for sure,push down on the to make sure They are not loose or pull out and put back in to reseat them.
They might of jarred loose putting in the fuse box.
Look at the connectors on the box as well.
thanks coblasts. actually found the answer to my problem in another thread where you mentioned the ip ign fuse to help another guy lol. replaced it and everything works except the fog lights argh ill have to look at that fuse too
