Bad Igition Coil Harness issues?
Old Sep 2, 2013 | 02:50 AM
Erik's Avatar
So has anyone on here experienced an ignition coil harness going bad? I keep getting a CEL giving the code P0352 which indicates a bad circuit for coil "B" which I'm assuming is coil number 2?? I changed the coil out and still the same problem. Then I tested the harness by checking continuity from every plug down to the part where it connects to the main harness and all was good. Then I tested continuity for the main harness, and again, all good. I think I might be getting a bad connection somewhere, but again, just want to know if anyone else has had this issue?? Is this a common problem on the LSJ's?
Old Sep 9, 2013 | 12:43 PM
Erik's Avatar
dennis69
Oct 20, 2015 07:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
Tupp
Sep 30, 2015 08:18 PM
Iceberg
Sep 29, 2015 12:33 PM
SlowSaturn
Sep 28, 2015 11:03 AM
