Bad Knocking in bottom of engine
Old Aug 28, 2015 | 12:48 AM
omarsiphone's Avatar
I have a 2.0 LSJ Supercharged. Head has fully been rebuilt, Valves, springs, rockers, keepers all brand new, head gasket has been replaced along with exhaust manifold gasket and intake manifold gasket and supercharger gasket, also has been properly retimed with new cam gears, timing chain, and guides. When i came to start the car after putting it all together it took a while to start. After finally getting it started, there is a rough knock coming from the bottom of the engine. The knock gets faster the more the throttle is applied. A buddy of mine did a compression test and found that cylinder 3 has low compression. I got the oil pan off but i dont wanna just go digging blindly. Car will not stay running. Any suggestions on what this might be? Kind of a noob so dont judge me.
Old Aug 28, 2015 | 12:06 PM
Bluelightning's Avatar
Got Bewst?
Gen 3 LSJ Short Block - Engine
Old Aug 28, 2015 | 01:06 PM
Agreed, just buy this from ZZP and replace the lower end.
The sound is more than likely rod knock. Did you cycle the engine over to build oil pressure prior to turning it over after all the replacements?
Old Aug 28, 2015 | 03:32 PM
Yea i did. But would just replacing pistons rods rod bearings and piston rings do it?
Old Aug 28, 2015 | 04:11 PM
If the crank isn't screwed. But honestly it's going to be quicker and potentially cheaper (long run) to just pick up zzps or hit up MrB or Mongo if you're just staying with the M62 blower
Old Aug 28, 2015 | 04:59 PM
I got the oil pan off. and the timing loose. i can't turn the crank. am i missing something?
Old Aug 28, 2015 | 06:33 PM
Compression stroke. Take the plugs out, unless you seized a piston
Old Aug 28, 2015 | 07:35 PM
I think i seized a piston, the head is completely off and the crank still won't turn. Car is not in gear. I dont know what to do now.
Old Aug 29, 2015 | 10:00 AM
Can you see scoring on the cylinder walls?
Old Aug 29, 2015 | 12:07 PM
Yes. But its not heavy scoring.
Old Aug 29, 2015 | 12:12 PM
double clutch's Avatar
Do it once, do it right.
Old Aug 29, 2015 | 11:50 PM
no_ss's Avatar
Pics
Old Aug 30, 2015 | 12:53 AM
Originally Posted by no_ss
Pics
I found the problem. Cylinder three the rod was burnt and the rod bearing was torn up. When I can figure out how to add pics. I will.
Old Aug 30, 2015 | 12:59 AM
Facebook Post
Old Aug 30, 2015 | 02:12 AM
Haven07's Avatar
Damn...
Old Aug 30, 2015 | 12:37 PM
Holy oil starvation. How long did the block sit open?
Old Aug 30, 2015 | 06:40 PM
only for about a day. But i found the problem. It was one of the piston oil squirters that broke off on cylinder 3 caused the rod to go bad and the bearing to mess up.
Old Aug 30, 2015 | 07:49 PM
Got Bewst?
Holy ****. But oil squirters don't just "break off". Regardless revert back to post #2.
Old Aug 30, 2015 | 07:53 PM
Qfe
Old Aug 31, 2015 | 02:22 PM
mrbelvedere's Avatar
that is not an lsj it is a gen3 ecotec
Old Aug 31, 2015 | 02:28 PM
the oil squirter being broken off is not caused the rod bearing to fail as it has nothing to do with lubricating the rod bearing but what caused the oil squirter to break off was probably excessive bearing clearance allowing the piston to hit the squirter on the bdc transition
the purpose of the piston oil squirter is to cool the piston crown for cooler piston temps
Old Sep 5, 2015 | 04:47 PM
SO because i spun a rod bearing what is the worst case scenario if i just swap the rod bearings, rods, piston rings, and the oil squirters and just put it all back together. without taking the crank to a shop?
Old Sep 5, 2015 | 08:23 PM
you will need to replace crank and go gen2 piston squirters and rods
Old Sep 5, 2015 | 08:33 PM
Got Bewst?
Who argued that it wasn't? Lol
Bang for the buck it's hard to beat for a replacement is all.
Old Sep 26, 2015 | 08:59 PM
This is gonna sound like a stupid question but how do i start a new thread or new post? i can't figure it out.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Oct 13, 2015 09:32 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
