Bad Paint / Recall ? Anyone else?
Old Mar 31, 2007 | 05:59 PM
Coblasts's Avatar
I think its the yellow paint.Ive got 15 chips on the hood and even one on the roof.
Im thinking bug deflector for next winter if the dealer doesnt do anything about the paint.
I read some where on here a while ago that someone did get there hood repainted.
The paint is to hard and cannot take the smallest impact with out chipping.(not adhereing to the primer or base coat.
Old Mar 31, 2007 | 11:15 PM
Supercharged06's Avatar
yea whats the deal w/ paint chiping and warrenty coverage i have 8 chips on my hood 1 of them being really bad and i am also starting to get orangish dots on the trunk of my car and no matterhow hard i try to clean it they wont come off it seems like its in the paint
and also the paint on my rims is chipping
Old Mar 31, 2007 | 11:20 PM
CTSSBowtie's Avatar
You think all thats bad... There is overspray on my hood from when they refinished my passenger fender. Theres all these whitish spots all over that side of the hood... and they didnt even take care of those chips on the hood when it was there!
Old Mar 31, 2007 | 11:34 PM
HickOverLOrd's Avatar
Yeah I got quite a few as well. Theres always construction zones where ever you look and plus its a desert. I do think this car chips more than my 01' Blazer though.
Old Apr 1, 2007 | 02:36 PM
CTSSBowtie's Avatar
im thinkin it chips more cuz of the layered paint...base coat, metal flake, color, clear...
course i could be wrong...
Old Apr 1, 2007 | 03:05 PM
1BadBlueSS's Avatar
I have 2 chips on the passenger side door.....Have no f'in clue how they got there.
Old Apr 2, 2007 | 12:10 AM
rukkee's Avatar
My black cobalt seems to scratch if you just look at it , the clear on these cars must be close to non-existant . I stored mine for the winter and it still looks like **** at the bottom of the doors and behind the wheels . The paint there seems smooth but it looks like a ton of tiny pebbles hit (sandblast)and they are white . My car was parked when the sand was on the roads . ERRR
Old Apr 2, 2007 | 07:46 AM
xrayrick's Avatar
Mine had swirls all in the paint from railroad dust. Then first time I went to rinse the dust off of it the high pressure washer blew a piece of paint about the size of a quarter off the roof of mine. I had them repaint the top and completely compound and redo the rest of the paint. The dealership made good on all of it . Happened with less than a thousand miles on her.
Old Apr 2, 2007 | 08:06 AM
dedecv3's Avatar
Would it be possible to maybe have extra clear coats put on?? To help protect the paint??
Old Apr 2, 2007 | 08:39 AM
kenhebe's Avatar
Originally Posted by sSsuPerChaRgEd07
well you better complain to the dealer cause the warranty covers that. NO car should be chipping at even 40,000 miles my 94 mustang gt still has a beautiful paint job not 1 chip and that has 154,000 miles on it. i noticed my cobalt scratches REAL easy these paint jobs are cheap as ****. im already gonna complain about the scratches cause it shouldnt scratching as bad as it does with a cloth over a wet surface. the second mine chips im gonna tell them to give me a real paint job and not this cheap **** not sure what will happen but definatly bitch to them.
You have no idea what you are talking about. Every car gets paint chips. The severity of which depends on where you drive. This is absolute lunacy that some of you think a manufacturer should warranty against paint chips. It does not matter if you bought a $10000 Aveo or a $70000 Corvette ZO6. They will both get chips no matter what you do. It will even happen on any Mercedes, BMW, Porsche, Ferrari and any other manufacturer in the world. I manage a collision center and see it all. Every car ever produced regardelss of whether Dupont, PPG, Sikkens, or Spies Hekker paint was used gets chips, scratches, and swirls. There is no such thing as a paint that does not swirl, scratch, or chip. Something else to keep in mind is that the lower your car sits, the more chips you will receive.
You are wrong. The paint used on most vehicles today is what is known as a basecoat/clear coat formula. The basecoat is your color. When your color is applied it is flat. It has no gloss whatsoever. Unless your car is a pearl white like on Cadillac's, any metal flake or pearl is in the basecoat. Then your clear goes over that to give it it's gloss. So it is not a 4 step process, just 2.
I am interested to find out by you how you know if a car has clear coat on it or not. I am just curious to see what some of the responses will be.
It is a bad idea to have any more than 3 solid coats of clear on a daily driver. If you make the clear coat too thick, then instead of it chipping it will start chunking. You will have large chunks of material coming off. That is much worse.
Old Apr 2, 2007 | 08:47 PM
  #36
d_backer1's Avatar
You can tell that you have clear one way is when you wash and wax your car color will come off onto the cloth if there is no clear coat, and most cars produced after '95 have clear on them...check for paint codes that start BC/CC or BCCC (base coat, clear coat)
Old Apr 2, 2007 | 08:52 PM
  #37
tREBs's Avatar
happens to me as well
Old Apr 2, 2007 | 09:26 PM
  #38
kenhebe's Avatar
That is kind of correct. If you wax your car and color comes off, then it is what is known as a "single stage" paint job. It never had clear to begin with. You are right about the 95+ thing though. Basically on a base coat clear coat paint job, if it does not have clear, it is not glossy. Pretty simple.
Old Apr 2, 2007 | 09:30 PM
  #39
xtremeGM's Avatar
I have rock chips all over the hood. It really ticks me off. But I doubt any dealerships around here would do anything about it.
Old Apr 2, 2007 | 09:40 PM
  #40
pimpnwink's Avatar
kind of off topic but i have a question. If you have have problem that can be covered by warrenty on the car do u take it to the dealer you got it from or a GM Goodwrench center thanks in advance.
Old Apr 3, 2007 | 12:18 AM
  #41
kenhebe's Avatar
It must go to a dealer, but does not have to go to the dealer you bought it from.
Old Apr 3, 2007 | 07:00 AM
  #42
Dead Zen's Avatar
5800 miles and my hood is fucked. This sucks.
Old Apr 3, 2007 | 10:52 AM
  #43
Claudia SS's Avatar
The paint on my bumper is starting to flake off.
Also, the chevy badge on the front fell off at the carwash.
Old Apr 3, 2007 | 03:46 PM
  #44
ReMz's Avatar
I have the same orange-ish dots on my trunk (and only the trunk). Same exact problem you are talking about.
I regularly wash and wax my car as well...... I'm thinking that this is probably a warranty issue. Chips are going to happen regardless of the paint. So i doubt that is warranty.
Old Apr 7, 2007 | 05:30 PM
  #45
Coors's Avatar
The front of my hood has about 20 rockchips, like it was sandblasted.
She'll be two months old tomorrow!
Old Apr 7, 2007 | 07:33 PM
  #46
!AzCobalt!'s Avatar
Can't bitch about it to much here in AZ...one of ADOT's favorite way's to repair our **** roads is "CHIP SEALING" sucks ass tiny little pebbles all over the road and bouncing off your pride and joy Damn gotta bump myself just realized post #
Bump...to save me from the devils # Your killing me with the automerge aggggggggggh!
werd...
Old Apr 7, 2007 | 07:54 PM
  #47
rickyw's Avatar
my paint is pertty bad sometimes too.....
Old Apr 7, 2007 | 07:59 PM
  #48
G5GT2007's Avatar
i have a good size one on the tip of the hood then one right on the fender then 2 on the top of the hood and i have 5400 miles on it. once they sweep the roads im going to take it in
Old Apr 8, 2007 | 12:00 AM
  #49
camarokiller's Avatar
Not trying to be a smart ass, really. How pissed can you be about the paint quality? Theese are just 10,000 dollar cars with a blower bolted on lol. I live in the woods, really, and have not had one problem with my paint 14K later. I did however put a small scatch in my bumper with my bicycle.
Old Apr 9, 2007 | 08:16 AM
  #50
kenhebe's Avatar
The paint used on the $10,000 base model Cobalt is the exact same stuff that GM uses on every other car. Even the Corvette or Cadillac CTS-V. They all get the same materials applied.
