Bad wheel bearing/hub?
When turning, I notice a squeak like sound on the front passenger side, and when braking my ABS pre-maturely engages, causing the idiot light to come on. Im thinking possibly bad wheel hub/bearing? Wasn't sure if this was common for these and/or if anyone would know what the deal is.
If you have scan tool you can display data from wheel speed sensor to see if they display the same thing according to you speedometer. If one is bad it will display incorrect speed and you will need to change it because abs engage when wheel speed sensor detect a certain difference between wheels speed. It might be possible that the noise your hear is the abs pump.
Hope it helps. Good luck!
