battery problems
Old Dec 16, 2007 | 11:45 AM
boostnss's Avatar
battery problems
i have been though 2 batterys in the past mounth i boutght optima red top one lasted about 3 weeks and then it stoped taking a charge so i got a new one on monday went out to start the car this morning and it was dead any one eles run to this before?
Old Dec 16, 2007 | 11:47 AM
an0malous's Avatar
first time ive heard that one.
do you have anything aftermarket drawing power?
Old Dec 16, 2007 | 11:50 AM
boostnss's Avatar
i did but it is all out of the car now has been for like 3 months i don't understand it.
Old Dec 18, 2007 | 01:20 PM
rnjmur's Avatar
Sounds like a short in the system somewhere. If you have an aftermarket system something is not hooked up correctly. If you have pulled EVERYTHING out and put it back to stock there is still something that is shorting out the system. Could be that the alternator has shot crap as well.
Old Dec 18, 2007 | 01:23 PM
RaineMan's Avatar
could be the alternator...
Old Dec 19, 2007 | 09:08 AM
boostnss's Avatar
yea i checked the alternator a couple of times and they said it was good.
Old Dec 19, 2007 | 09:43 AM
monkeiboy's Avatar
Remember the good ol days when it actually WOULD be the alternator.
god I miss my 78' chevy
Old Dec 19, 2007 | 09:45 AM
D4u2s0t's Avatar
check your grounds. if you went through 2 batteris, and the alternator is good, then it's probably a bad ground somewhere. i would pick up a cheap voltage meeter so you can keep an eye on it.
Old Dec 19, 2007 | 09:46 AM
redlineblueline's Avatar
do the old diy alternator test...start car..undo negative battery terminal...if car keeps running alt. is good
Old Dec 19, 2007 | 12:51 PM
boostnss's Avatar
yea well for that couple of days it has started it's a little slow in the morning but after that it's fine im going to look over every thing this weekend and see if i come up with anything. Thanks for the help everyone.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
