Battery Terminal Issues?
Old Sep 28, 2006 | 10:12 PM
HackAbuse's Avatar
Is Anyone else having issues with their battery terminals failing? The design on these things are so horrible! How the helll can you expect to just drop a ring on a battery and hope it makes a good connection
Mine frequently drops the connection upon startup, which, in turn, locks my key in the ignition and prohibits me from opening the trunk in any way. I know there is a TSB out for this issue, but I have a feeling the dealer will point to the wiring for my subwoofer and say "Gah, aftermarket accessorie! These definitely caused the corrosion!!"
I currently have to leave one seat unlocked so that if the car loses connection during startup, i can climb into the trunk and tap the terminal to get power again.
Any sugeestions?
Old Sep 28, 2006 | 11:22 PM
Clmbngfrk18's Avatar
minw was letting go at one time but then i relized that my amp connection was causing it to loosen up whuch side is comming undone mine was the negative side all i did was move the ground wire from directly conneted to the battery to the end of the battery ground wire
Old Sep 29, 2006 | 06:56 AM
HackAbuse's Avatar
Both of mine are loose, I actually blow torched the negative side on with some solder and got a good connection, but the positive side i cant get hot enough to melt solder
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
