Bleeding brakes help
Hello forum,
I recently took my front 2 calipers off to paint them( 07 lsj).
2 days later I put them on, bleed them, hand vac bleed them and i still have no pressure in the brake pedal. I been at this for a few day. Any help?
Just to verify you are bleeding in this order
LR
RF
RR
LF
Also mabe some can cone in and verify this but I believe it is possible to damage the master cylinder by overstroking it caused by low fluid or rapid pumping or something
LR
RF
RR
LF
I believe it's passengers back then front then drivers back then front.
LR
RF
RR
LF
LR
RF
RR
LF
https://www.cobaltss.net/forums/how-...-brakes-59164/
I wouldn't bother bleeding the rears if you didn't disconnect them.
I have bled it every way possible even the correct order even with the rears
Fluid comes out with a nice flow. Once I start the car and has zero breaks
I have hurt I may need a scan tool to bleed the ABS module.
Has anyone heard of this or did this?
Didn't think taking my calipers off would run into a pain in ass like this
Good luck bleeding the ABS module. My system ran dry a few years back. The only people I could find to open the ABS ports is chevy. My buddy manages an Exon and even he tells me that he doesn't have the tools to open the ports. If those lines are dry you would still have good brake pressure. My brakes are very responsive still. Just a bit mushy for the first bit, then perfectly fine.
If you're trying to get out every last drop of old fluid, then yes, you'd need the tool to cycle the ABS. Or you could do like some people do - find a wet or icy road and slam on the brakes a few times. Then bleed the whole system again.
Or not worry about it. I'll bet if you went to Midas or some place like that they wouldn't bleed the ABS.
Say, is it possible you have the calipers on the wrong sides? Bleeders would be on the bottom if they're on the wrong side.
I'm not sure how I did that LOL. The only difference was the nipple was on the bottom
Everything else looks exactly the same
Or I was tired LOL just got done putting the engine in fully built with the TVs
