Bleeding Clutch
Bleeding Clutch
The wire wound flex hose between the master cylinder and the slave that has steel tubing with conectors, does it have to be as per specks or can I use another type of hose.
Also curious as to what the pressures are on this hose.
This clutch is on a 1983 Chevy 1/2 ton.f
Thanks,
budz
Thanks,
budz
