? Bleeding the SS/SC clutch ?
Clip
did you ever figure this out? I am in the same boat I’ve gone through about a gallon of brake fluid bleeding it and I’m still getting air coming out so I don’t know what I’m doing wrong I’ve got pedal but the car won’t go into gear just put a new motor in the car
I have the same problem!
were you able to figure it out? I have gone thought a lot of fluid and still getting air! Please help! I changed the clutch master cylinder and now I just can’t get rid of the air! Any ideas?
I had ended up having to put a clutch kit in throw out bearing and all the throw out bearing was bad
QUOTE=Daniel Rangel;7710622]
did you ever figure this out? I am in the same boat I’ve gone through about a gallon of brake fluid bleeding it and I’m still getting air coming out so I don’t know what I’m doing wrong I’ve got pedal but the car won’t go into gear just put a new motor in the car[/QUOTE][/QUOTE]
TonyTuna
Feb 11, 2012 02:23 PM
