blower motor tick
Old Oct 31, 2009 | 10:58 PM
DeepBlack SS's Avatar
blower motor tick
got a tick coming from my blower motor, pulled out the cabin and felt around to see if I could find any leaves or anything but no luck, any ideas?
Old Oct 31, 2009 | 11:18 PM
ziggity's Avatar
Does it happen just during idle? If it does its most likely timing chain tensioner.
Old Nov 1, 2009 | 12:30 AM
no, its definitely the blower motor. it only happens when the blower is on and the ticks get faster as you turn it up.
Old Nov 1, 2009 | 12:35 AM
Rydis's Avatar
I have a similar problem. Have yet to find out the source.
Old Nov 1, 2009 | 12:36 AM
boost_junkie16's Avatar
Sub'd for solutions. I have the same problem with my '06 Cobalt SS/SC too.
Old Nov 1, 2009 | 01:07 PM
Coblasts's Avatar
Its either the bearing or the cage is touching somewhere.Those types of motors tend to move forward
when the bearings start to wear .
So I would say its rubbing at the front of the cage.
You cant lube the inside bearing with out removing the cage from the motor shaft which is a pain but can be done with some patientce.
Old Nov 8, 2009 | 06:39 PM
nwalke's Avatar
I've had the same problem in mine. I was told on here a while back that it was a warranty fix, but my car is salvage, so not good news for me.
Old Nov 8, 2009 | 07:07 PM
Rydis's Avatar
when I brought mine to the dealer they said it was my aftermarket pulley lol.
Old Nov 8, 2009 | 07:10 PM
slowswap's Avatar
You people do not know the difference between a blower motor and a supercharger.
******* hilarious.
Old Nov 8, 2009 | 07:12 PM
leviticus88's Avatar
He isn't talking about a supercharger... FYI
Mine does it also, just turn the music up. lol
Old Nov 8, 2009 | 07:24 PM
slowswap's Avatar
Exactly yet some people are naming off timing chain tensioner. LOL
Old Nov 8, 2009 | 07:33 PM
08G5GT2.4L's Avatar
******* hilarious.
Indeed it is
Old Nov 9, 2009 | 10:19 AM
mrfitz's Avatar
I just noticed the same thing. Pain in the ***** noises. I was like "WTF???" then I turned the fan off and it went away. Retarded. Thats one noise that Im not interested in chasing down.
Only does it with the heat on though.... not ac.
Old Nov 9, 2009 | 12:16 PM
Rydis's Avatar
******* hilarious.
I said dealership said it was the pulley, not I, thats why I had the there
Old Nov 9, 2009 | 11:34 PM
rukkee's Avatar
My 06 did this too .....haven't had that issue yet with the new one.
******* hilarious.
You know how it is around here Slows .... it couldn't have surprised you after all the other **** we've seen lol
Old Nov 27, 2009 | 07:11 PM
JohnyNFullEffect's Avatar
I have no warranty anymore. Too many miles, too old. How much is a blower motor if I wanted to replace this myself? Sounds like a PITA having to cut the casing to replace it.
Old Nov 27, 2009 | 07:37 PM
Nighthawk243's Avatar
It is a common issue for the HVAC to be noisy. It sounds like someone's jamming a card into a computer fan at lower speeds.
Mainly I get around it just by cranking the music.
ThoR294
Oct 4, 2015 08:44 PM
jimbofug007
Oct 2, 2015 12:06 PM
Stuff
Oct 1, 2015 05:47 PM
ThoR294
Sep 28, 2015 05:31 PM
goaliemo
Sep 28, 2015 01:37 PM
