Boost Bypass Solenoid
first off take the bottom line off the actuator, if you hear vaccum coming from either line one of them are bad, easy way to tell if there bad. if you have a code check it, and you can go from there. Also itll gve you a shitty idle if you have a vacuum leak
The thing is its not throwing any codes
Sl0wbaltSS
Nov 21, 2018 11:11 PM
