Boost Gauge not reading right...
Old Jun 21, 2008 | 04:51 PM
Stouffer's Avatar
I installed the Intercepter today. Everything is hooked up right. Now the stock boost gauge doesn't read right. It only shows boost to about 10-11psi and vacum drops to aorund. 30 where before it would stay around 19 in vacum. The Intercepter reads everything right. Showing vacum at about 19-20 and boost up to about 16. Other notes I do have a 2.9 pulley. Any thoughts as to why the stock gauge doesn't work right now???
I have searched for some answers and can't find a dam thing.
Old Jun 21, 2008 | 05:14 PM
Turbo06Sedan's Avatar
Stock SS/SC Electrical gauge? or did you recently go with a mechanical?
take it in for warranty as something is fubar'd
Old Jun 21, 2008 | 05:19 PM
Stouffer's Avatar
Stock Boost gauge.
Old Jun 21, 2008 | 05:22 PM
Timster06SC's Avatar
my boost gauge got stuck at 0psi and wouldnt do anything..dealer replaced the gauge hasnt happened since
Old Jun 21, 2008 | 05:26 PM
Stouffer's Avatar
That's fine. But it worked fine this morning and after the Intercepter is when it fd up this afternoon. So I think it is just something simple I am not seeing or haven't thougt to look at.
Old Jun 21, 2008 | 06:13 PM
Check to make sure the electrical leads for the boost gauge didnt get bent/pulled out/crushed/cut..etc.
Theres not a whole lot you can do since its a electric gauge...if it was mechanical...id say you have a boost leak.
But your car should NEVER see -30 In Hg(Vac) while on...only when off. You should be right around -20
Last edited by Turbo06Sedan; Jun 21, 2008 at 06:13 PM. Reason: Automerged Doublepost
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
