New noise...please help.
Old Jun 15, 2008 | 11:19 PM
Jplaya023's Avatar
I recently started hearing this noise within the past few days and its only coming the passenger side front wheel. it sounds almost like a tire rub but i know thats not the issue because i checked for clearance and everything is fine. its only when i turn the wheel about 180 degrees to the right that i hear it. if i turn it past that the noise goes away and if it turn it less that that there is no noise. im not sure what it could be but it sounds similar to a stick dragging on the ground lol.
thanks for any help guys
Old Jun 15, 2008 | 11:27 PM
chris88z24's Avatar
wheel bearing possibly.
Old Jun 16, 2008 | 08:58 AM
RoAdsZ24's Avatar
check your brakes for damage or if the caliper or pads are loose
could also be your CV joint since it only makes the noise when you are turning
Old Jun 22, 2008 | 12:23 AM
Jplaya023's Avatar
turns out a piece of the inner plastic wheel well was rubbing...go figure huh...glad it didnt cost me anything tho! thanks for the help tho...greatly appreciated!
turbochargedss2012
Sep 20, 2023 12:17 PM
Sep 30, 2015 07:22 AM
twilson380
Sep 14, 2015 10:52 AM
CobaltSS 16
Sep 12, 2015 02:43 PM
