Boost Gauge not working.
Old Sep 21, 2010 | 06:01 PM
WHAT LAG's Avatar
Just picked up a 2005 SS/SC last night. So far everything is great except for the boost gauge. It doesn't read at all, and is stuck on -15 or something. It is as if the gauge isn't hooked up at all. I took the pillar off and everything seems to be plugged in pretty solid, and nothing seems to be unplugged under the hood either. Before i take it to the dealership i want to make sure its not something simple like a fuse or something. Any ideas? Is there a separate fuse for the boost gauge? I did not see one anywhere.
Old Sep 21, 2010 | 06:06 PM
kxrida2000's Avatar
Probly the gauge man
Old Sep 21, 2010 | 06:33 PM
iboost's Avatar
does it light up or anything?
Old Sep 21, 2010 | 06:49 PM
WHAT LAG's Avatar
Actually, yes. I just realized that.. it DOES light up, but the needle does not move.
Old Sep 21, 2010 | 07:03 PM
Bl4des's Avatar
just get a new one i have seen a few of them just stop working
Old Sep 21, 2010 | 07:07 PM
WHAT LAG's Avatar
Alright, yea. I was planning on taking it in to get fixed under the warranty, but didn't want to waste my time if it was something simple. Doesn't sound like it is though.
Old Sep 21, 2010 | 08:23 PM
iboost's Avatar
i have a cobalt repair manual at work and I'll look it up and see if there is anything super simple you can check out
Old Sep 21, 2010 | 08:26 PM
Chevycobaltss3's Avatar
It's the gauge I have repleace two in some Balts not
mine just people they are junk
Old Sep 21, 2010 | 08:39 PM
FRSTGRDEDROPOUT's Avatar
Did the dealership replace somthing? Do the wipers work? If not Check the 10amp WPR fuse #15 on the bcm. Ther is a panel on the right passenger side of the center console under under the radio you need to remove to get to the bcm. Its held in with push clips and the bcm is right behind it.
Old Sep 21, 2010 | 09:18 PM
If the fuse was blown then the gauge wouldn't have power te needle is moves
by the ecu it has a pig signal so the gauge is bad I say go with a mechanical gauge
Old Sep 21, 2010 | 09:33 PM
ecot3c inside's Avatar
It's probably the gauge itself. I bought my 06 ss/sc and the gauge lit up, but didn't move. Replacing it takes like 5 mins.
Old Sep 21, 2010 | 10:52 PM
WHAT LAG's Avatar
Windshield wipers work, and i checked the 15 & 16 fuses (16 said boost on it) and they are both fine. Considering the gauge lights up still, i am going to agree that the gauge is bad and needs to be replaced. I'll take it to the dealership and see if they can just give me a new one under warranty instead of install it for me. Thanks for the help guys.
Old Sep 21, 2010 | 11:04 PM
The Lights for the gauge are on a differnt fuse and circuit than the control for the gauge.
But it probably is a bad gauge
Old Sep 22, 2010 | 01:21 AM
WHAT LAG's Avatar
Do you happen to know which fuse the control for the gauge is on? It is worth a try before i spend all of convincing the dealership that this should be fixed under the warranty.
Old Sep 22, 2010 | 01:30 AM
cmatthewb101's Avatar
Dude, just take it into the dealership since you have a warrenty. The gauge is junk. It's covered.
Old Sep 22, 2010 | 05:09 AM
the fuse for the light for the boost gauge is the cluster lights and tail lights fuse i am pretty sure.. hope all works well
Old Sep 22, 2010 | 05:31 PM
The boost gauge lights should be on the Int lamp fuse. And according to the schematics the control circuit is powered by the WPR fuse.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
