Boost Problem 9psi???
Old Oct 24, 2008 | 12:22 AM
Sta-meng's Avatar
Exclamation Boost Problem 9psi???
I have a stage 2 with a 2.9 and i was pushing 16-17 psi for months. On my drive home tonight i saw that its only making 9psi to redline every gear. I just changed the oil on it maybe 2 weeks ago and its got 41k. STock exhaust system, And a k&n cai. NEED HELP
Old Oct 24, 2008 | 12:28 AM
Greased's Avatar
any funky sounds? sounds like you might have a boost leak somewhere or a bad boost gauge
Old Oct 24, 2008 | 12:30 AM
Sta-meng's Avatar
No no sounds or anything. and i thought maybe my boost gauge but it shows up on the interceptor gauge that its only making 9 psi. I also got out and felt my supercharger and it was as cold as ice.??
Old Oct 24, 2008 | 12:46 AM
Bika's Avatar
Fail Less.
bad boost bypass solenoid or disconnected vac line on the bypass valve.
Old Oct 24, 2008 | 12:50 AM
ACESSbalt's Avatar
i recently had been only gettin 5 maybe 7 when i had a boost leak at my gauge and car ran like ****... just have to find where the leak is if its a leak
Old Oct 24, 2008 | 09:56 AM
Sta-meng's Avatar
Does any one have a pic of where this is under the hood??
Old Oct 24, 2008 | 10:11 AM
freakta's Avatar
right on top of the sc... it looks like a little black wastegate... pull off the hose and see if it helps
Old Oct 24, 2008 | 11:29 AM
Sta-meng's Avatar
the last time i did that it made it idle really low and it would jump up, and felt like it didnt want to stay running.
Ok i unpluged the one vacuume line from the Sc to the wastegate looking thing and its just it runs perfect. I got all 17 psi's. But wont i throw a CEL ? I did a while ago when i had it off for a few days.
Old Oct 24, 2008 | 03:33 PM
Bika's Avatar
Fail Less.
as long as you seal off the line you pulled so you dont have a vac leak, you wont have any code.
Old Oct 24, 2008 | 04:21 PM
Psykostevo's Avatar
Sounds like a classic case of Intercooler pump failure. When you IC pump fails and the car sees extreme IAT2s it puts the car into a retarded mode different than Limp Mode. Check the IC Pump first before changing any parts.
Old Oct 25, 2008 | 04:40 PM
Bika's Avatar
Fail Less.
ahh yes. i forgot about the failed I/C pump. but i dont think it pulls that much boost. usually IAT boost is set at 80%. he was getting about 50%
Old Oct 26, 2008 | 12:01 AM
Doubletg13's Avatar
i have a question if anyone can help... i noticed a few weeks ago that my exhaust sounded kinda funny and now im boosting like 17.5-18psi.. i have the gm stage 2 kit.
Old Oct 26, 2008 | 12:05 AM
theneelster's Avatar
yep
Or it could be your intake vac line (or in my case it was a line on my catch can)
clogged cat.
Really? That's strange. I never got that (redline) and I was running without the i/c pump for maybe 1k miles because the relay was detached from the fuse box. Temps didn't get crazy high either. (maybe 165)
Last edited by theneelster; Oct 26, 2008 at 12:05 AM. Reason: Automerged Doublepost
Old Oct 26, 2008 | 12:06 AM
Doubletg13's Avatar
would a clogged cat throw a cel? and i also put the megan racing exhaust on after this so would it be clogged in the downpipe?
Old Oct 26, 2008 | 12:31 AM
Nope (as far as I know). I think the 2nd o2 sensor will still read that there is less exhaust (ie the cat is working) otherwise it would throw probably p0420. It won't be clogged in the downpipe it will be clogged in the "cat body" you're going to probably have to either gut the cat or cut it out and weld a new one on, or get a new head/dp. If you replace the cat go with a high flow cat, vibrant and (I believe) magnaflow sell them also random technology.
Old Oct 30, 2008 | 06:50 PM
fzn14's Avatar
Safe to unplug the line and cap each side? Long term effect?
Old Oct 30, 2008 | 06:55 PM
mkulrey13's Avatar
My buddy has his vac line unplugged for over a year now. given hes tuned for a 2.7 meth and such hes never had a problem. He was only pushing 9ish PSI before he unplugged it.
Old Oct 30, 2008 | 07:27 PM
fzn14's Avatar
I pulled the line of the acutator, Not the back of the bypass....
the one going from the acutator to the bypass
Old Oct 30, 2008 | 07:34 PM
I think that's a bit high for a 2.9 maybe not with the stock exhaust... But yeah...it's a boost leak probably at the vac hose to your intake.
Old Oct 31, 2008 | 11:48 AM
Psykostevo's Avatar
It's not IAT boost, it's like a cripple effect. After seeing the problem it wont throw a code but it will lock boost in under 10psi no matter what pulley you have.
Old Nov 1, 2008 | 01:21 AM
Bika's Avatar
Fail Less.
so when the ic pump fails the ecu will automatically kill boost? did not know that
what i was looking at was the tq management section of HPTuners where it has COT boost %, IAT boost %, etc.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
