Boost Problem 9psi???
I have a stage 2 with a 2.9 and i was pushing 16-17 psi for months. On my drive home tonight i saw that its only making 9psi to redline every gear. I just changed the oil on it maybe 2 weeks ago and its got 41k. STock exhaust system, And a k&n cai. NEED HELP
No no sounds or anything. and i thought maybe my boost gauge but it shows up on the interceptor gauge that its only making 9 psi. I also got out and felt my supercharger and it was as cold as ice.??
Ok i unpluged the one vacuume line from the Sc to the wastegate looking thing and its just it runs perfect. I got all 17 psi's. But wont i throw a CEL ? I did a while ago when i had it off for a few days.
Sounds like a classic case of Intercooler pump failure. When you IC pump fails and the car sees extreme IAT2s it puts the car into a retarded mode different than Limp Mode. Check the IC Pump first before changing any parts.
yep
Or it could be your intake vac line (or in my case it was a line on my catch can)
clogged cat.
Really? That's strange. I never got that (redline) and I was running without the i/c pump for maybe 1k miles because the relay was detached from the fuse box.
Temps didn't get crazy high either. (maybe 165)
Last edited by theneelster; Oct 26, 2008 at 12:05 AM. Reason: Automerged Doublepost
Nope (as far as I know). I think the 2nd o2 sensor will still read that there is less exhaust (ie the cat is working) otherwise it would throw probably p0420. It won't be clogged in the downpipe it will be clogged in the "cat body" you're going to probably have to either gut the cat or cut it out and weld a new one on, or get a new head/dp. If you replace the cat go with a high flow cat, vibrant and (I believe) magnaflow sell them also random technology.
I think that's a bit high for a 2.9 maybe not with the stock exhaust... But yeah...it's a boost leak probably at the vac hose to your intake.
It's not IAT boost, it's like a cripple effect. After seeing the problem it wont throw a code but it will lock boost in under 10psi no matter what pulley you have.
so when the ic pump fails the ecu will automatically kill boost? did not know that
what i was looking at was the tq management section of HPTuners where it has COT boost %, IAT boost %, etc.
