Boost Problem & Now Engine Power Reduction!
Old Jun 14, 2015 | 01:27 PM
Drunkship's Avatar
Finally got my alternator issues fixed (melted ground) and now I have a whole new issue!
Ever since I cleaned my TB and moved the butterfly I've had a CEL throwing the P0171 code. The other day I noticed I wasn't building boost past 1psi. It would read 0 with the key clicked once and -20 at idle. The SC whine didn't become apparent until around 4k in each gear and it felt like it was down on power.
I re-bolted the TB and re-clamped the coupler from the intake to the TB. I tried listening for any apparent leaks from hoses and the BPV valve but didn't notice anything.
I was just out doing chores and all of a sudden the car went into enginer reduction mode and I limped it home. Would a boost leak cause this or is it probably something else?
Old Jun 14, 2015 | 03:09 PM
Drunkship's Avatar
Disconnected the battery for 15 minutes to see if it would clear, which it did (for now...). Drove around the block a few times to see if it would repeat and it didn't for now.
Old Jun 16, 2015 | 02:39 AM
megaman311's Avatar
did you remove the throttle body off the car when you cleaned it? sounds like a bad supercharger pressure inlet sensor...
brandon04
Oct 21, 2015 07:04 AM
vjoel2011
Oct 2, 2015 12:11 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
riceburner
Sep 26, 2015 12:57 AM
Dustonian131
Sep 23, 2015 08:03 PM
