Brake Question
Old Jan 3, 2009 | 12:46 PM
CaptainHook's Avatar
Brake Question
My brakes started wailing when I go in reverse, or roll back in neutral. What does this sound usually mean is wrong? and Is it covered by warranty. 2008 SS/SC
Old Jan 3, 2009 | 12:50 PM
steddy2112's Avatar
Couple of things wrong here.
First
This should be in the suspension section
Second
There is no such thing as a 2008 SS/SC
Third
It is normal and nothing to be concerned with.
Old Jan 3, 2009 | 03:28 PM
Erod's Avatar
Moderator Alumni
it means you should read my sig. moved
Old Jan 3, 2009 | 05:10 PM
Coblasts's Avatar
First
Second
Third
Explain to me why this is a suspension problem when hes talking about brakes sqeaking ?
And isnt this the problems section,Where you would post problems you have.
Old Jan 3, 2009 | 05:14 PM
RooTBeeR's Avatar
read the post above you...thread got moved to correct section already
Old Jan 4, 2009 | 02:08 PM
Sorry, 07.
Old Jan 4, 2009 | 02:11 PM
JimzSS's Avatar
Its possibly the parking brake shoes howling in reverse, mine do it when its damp outside.
Old Jan 4, 2009 | 02:25 PM
Sharkey's Avatar
there are no parking brake shoes in an ss, they use the caliper, actuated by a cable, for the parking brake.
mine started doing that to now since its been cold and wet, and now with all the road grime. after a couple stops it clears up.
Old Jan 5, 2009 | 06:41 PM
ceas's Avatar
if it is the brakes, they won't be covered by warranty, brakes are never covered
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
