Braking noise...
Old Jul 27, 2012 | 07:37 PM
Nick_tamr's Avatar
Braking noise...
I have a problem with my car... when I'm braking it's fine but when I release the pedal it's doing a little anoying noise (squiiick) and it's doing that all the time... it comes from my right rear drum...
I have in mind something with the oil pressure or anything in link with that... let me know if I'm wrong!
Old Jul 27, 2012 | 07:39 PM
Cobalt_Daddy's Avatar
if it's drum brakes it might not be adjusting itself. or the brake line is old and has collapsed on itself stopping the fluid pressure from releasing once you let off the pedal. that happened on my honda and it caused the brake to stay on or stick sometimes. just a thought.
Old Jul 27, 2012 | 07:58 PM
Nick_tamr's Avatar
I see I should look the brake line then... I know there's no rust under the car or anything else and I'm happy about this but it's possible that my brake line collapsed! But I'm not sure because the brake doesn't stick :/ but I'll look for sure thx man!
Old Jul 27, 2012 | 08:04 PM
you may not be able to see it.. the covering on the brake line might be fine :/ i couldn't see it on mine. just have you brakes checked or serviced or have a friend that is mechanically competant to pull off the drum and see what's going on.
Old Jul 27, 2012 | 08:07 PM
Nick_tamr's Avatar
Ok cool this is what I'll do then! thx for the clue because I hate how it sounds and anoying this is... -_-
Old Jul 27, 2012 | 08:09 PM
i know. mine stuck so bad i had the brakes glowing red hot. thought it was the caliper... expensive guess. should have went with the flex line first.
Old Jul 27, 2012 | 08:14 PM
Nick_tamr's Avatar
Oh my .... yeah this is expenssive :/ well your guess helped me because now you can help people with this experience
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
