breaks
Old May 27, 2007 | 03:07 PM
zzzzzzzz's Avatar
breaks
my brakes are making a grinding noise. when im stoped and have brakes on if i let off the break a little it ginds also when im parked and shift into drive and reverse with foot on break
Old May 28, 2007 | 12:58 PM
Brian's07SS's Avatar
more info would help. how many miles... ever have the brakes changed...type of driving(city/highway) Im sure someone could help with this...just not enough info on here.
Old May 28, 2007 | 02:47 PM
Mikey851's Avatar
So it ginds when you break? Haha j/k man.
Give us the cars history.
Old May 28, 2007 | 03:12 PM
cage's Avatar
Like the other im not an expert but my previous car (1989 Plymouth acclaim) had a grinding noise whenever breaking because the front calipers wouls seize up. Hopefully someone else will help you out more.
Old May 28, 2007 | 03:59 PM
RaineMan's Avatar
You need front brake pads... badly... and probably rotors now too.
That grinding sound is metal-on-metal contact. It can make your calipurs sieze up from excessive heat... keep driving it like that and you are gonna get in a wreck soon b/c you will be unable to stop.
Just hope a little kid dosen't run out infront of you...
Old May 28, 2007 | 04:06 PM
alaskacobalt's Avatar
The grinding could also be a rock wedged in your BRAKE system... Just take a good look at your brakes and if you see anything that doesn't seem normal, remove it, spray it down, and you should be good to go. But if there isn't anything there, definitely take your brakes in for some work by a professional, assuming that you aren't one since you are asking about them on here.
You could also have a warped rotor, but that is going to be more of a squeel than a grind. There could be dust in your braking system, it could be all sorts of things. One method that I was always told about was to just haul ass down a road and brake hard a few times, if you still hear grinding, get your **** checked immediately, if you hear squeeling, then you need new pads, and if it goes away it was just dust...
Old May 28, 2007 | 04:23 PM
cage's Avatar
It would be kind of odd for them to just start "grinding" and need new break pads. Normally they will have a "warning" by squealing for a good while before they start grinding. But yea, If you continue to dirve then your going to end up having to replace the rotors as well. But they can be machined back to regular if there isnt a lot of damage to them.
So go to a shop or dealer. Its not a good feeling when you push on the brake and nothing happens. If that happens just remember to use the gears as "brakes".
Old May 29, 2007 | 01:13 AM
rukkee's Avatar
Lol when ever the words brakes and grinding are in the same sentence , it means it's time to pull the wheel off and take a look .
Old May 29, 2007 | 01:18 AM
Word!
Old May 30, 2007 | 10:49 AM
well I figured that as well... but to most people its second nature to do that.. guess not for all.
Old May 30, 2007 | 10:54 AM
RaineMan's Avatar
I continue to be amazed at the number of "tuners" out there with no mechanical know-how or even the curiosity and guts to go out and try it.
Old May 31, 2007 | 01:38 AM
zzzzzzzz's Avatar
took the car in today and theres nothing wrong with brakes. turns out its my strut thats shot they just replaced strut few months ago how can that be
Old May 31, 2007 | 01:29 PM
it sucks sometimes things just break...even brand new parts...
they should replace the struts for nothing since you said its only been a few months...
Turbo Johnny
Feb 21, 2019 09:41 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Getaway_Driver
13
Aug 30, 2015 02:44 PM
ss xtreme
Feb 26, 2005 01:03 PM
