Brembo Brake Question
Old Jun 8, 2012 | 11:42 AM
Neodous's Avatar
I am changing over to EBC brake all around on my 2009 Cobalt SS and wanted to see if anyone knew if I would need to use the thin metal back plate (it is a thin metal shim that is between the brake pad shim and the pistons for the brake caliper). I would like to leave it out but I am not sure if it will be a problem later on.
Old Jun 8, 2012 | 11:47 AM
K-Train04RL's Avatar
Put it on. It helps with vibrations an noise cause by pad to rotor contact. U leave it out and u will make noises
Old Jun 8, 2012 | 12:34 PM
Neodous's Avatar
Well was hoping to leave it out but thanks for the info I will be leaving it in
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
