Brembo pins seized
Old Jul 13, 2013 | 07:53 PM
Wert842's Avatar
I have the wonderful thing of coming across this today. I wash gonna have a good day of cleaning my car and changing my brakes and rotors. Well I didn't get passed changing my brakes and rotors cause the damb pins are seized.
I've been pb blaster and wd-40'n them. Beat them with a nail set and a hammer and still nothing. I give up until tomorrow. I feel bad for whoever goes through the same thing. This blows. Can't do anything now.
Yay for the wonderful brembos!
Sent from my Samsung Galaxy S4 using CobaltSS
Old Jul 13, 2013 | 07:56 PM
kzak104's Avatar
how many miles? i ust recently took my pins out to lube them so they didnt sieze. they were just starting to rust at 30000kms
Old Jul 13, 2013 | 07:58 PM
Wert842's Avatar
Car just rolled over 31k miles. They beyond seized. They aren't moving at all. Haha.
Old Jul 13, 2013 | 08:02 PM
kzak104's Avatar
get a good pin punch, and fire up the torch, haha.
Old Jul 13, 2013 | 08:05 PM
kzak104's Avatar
these were mine.
Old Jul 13, 2013 | 08:21 PM
Wert842's Avatar
Mine probably look worse than that. I've punched the hell out of them for the last 3-4 hours and soaking them every once in a while in pb blaster and WD. It blows. I'm gonna keep spraying them and try and tackle it again tomorrow morning.
Old Jul 13, 2013 | 09:22 PM
slvrred-'s Avatar
Try soaking them in brake fluid. Helps break down rust fast. Use a 5/16 punch and use a decent size hammer with quick hard swings. If that fails, you could use heat from a torch but then you have to rebuild most likely. Other then heat you can cut them out with a dremel or cutoff wheel. Good luck.
Old Jul 13, 2013 | 09:26 PM
C_A_D88's Avatar
Def gonna need heat
Old Jul 13, 2013 | 09:28 PM
Wired's Avatar
What about pressing them out with a c clamp and a punch?
Old Jul 14, 2013 | 02:53 AM
tomj77's Avatar
try using penetrating oil, spray it on, let it sit for a while, then see if it comes out, tap the sides by the pin with hammer to lossen the rust so the oil can seep in there good.
Old Jul 14, 2013 | 02:55 AM
tomj77's Avatar
u know what would prevent this, before putting the pins back in, stray them with clear coat, let dry, it would prevent rust from forming. if it survives being put back in that is
Old Jul 14, 2013 | 08:27 AM
Wert842's Avatar
I'm trying a bunch of things today. Breaking out vice grips, clamps, big hammers, heat, and lube.
Old Jul 14, 2013 | 08:49 AM
GoodLuckBro's Avatar
Make sure you get the KY Stage 3 lube! Good luck man!
Old Jul 14, 2013 | 09:15 AM
gotboost?17's Avatar
Nothin Stock
i do brake service 2 times a year at least since my issue, ull have to use heat an most likely replace the puns once there out
Old Jul 14, 2013 | 09:27 AM
Spawne32's Avatar
i had the same problem on my car on my passenger side and i dont even have brembos, had to replace the entire bracket along with the pins
Old Jul 14, 2013 | 09:44 AM
Shift Hard's Avatar
I did a caliper service on them last year. Mine were pretty seized aswell. Fortunatelly i have my air hammer and a small drift bit that was good for shaking em free.
Old Jul 14, 2013 | 10:22 AM
Cobalt_Daddy's Avatar
ugh im about to do my pads and rotors on my brembos and this is the reason i'm not keen on doing it myself. i hear this all too often and i don't feel like beating them to death and burning them. the caliper will look like **** afterwards.
your car driven all year round wert? and what conditions do you live in?
Old Jul 14, 2013 | 11:45 AM
Nothin Stock
if I remember correct the only thing holding the pins in, is where the head on the pin is, the front of the pin where u see all the time is just a follower so u should be only heating up on the back side, but I do suggest anti seaizing the hold pin afterwords, my pins pop out like butter, 500$ later at the dealer
an mines a DD
Old Jul 14, 2013 | 11:58 AM
Wert842's Avatar
Still having no luck. Probably gonna have to remove my calipers and drill them.
My car only sees partial spring, summers, and half of fall. Its my dd during those months. Other than that its a garage queen.
Old Jul 14, 2013 | 12:54 PM
hmmm ... me thinks i will let the dealership do this. mine is a garage queen too with only 41k on it and it only sees later spring, summer and beginning of fall.
so many people claiming this was easy and that mine wouldn't get seized if it wasn't winter driven.
i think some of those people were talking through their asses or got lucky.
Old Jul 14, 2013 | 01:45 PM
Wert842's Avatar
Ya probably. I called a buddy at who works at a garage and he said they pop right out. I just laughed and he said they're easy. They're OEM brakes and rotors and have never been messed with.
Old Jul 14, 2013 | 01:51 PM
At least try it yourself first, before just handing it over to the dealer
Old Jul 14, 2013 | 01:55 PM
Wert842's Avatar
I did and it ends up I have pb blaster and wd-40 all over the caliper and a bunch of nail punch marks on it as well. Lol. Buuuuut my caliper paint should be coming soon to cover the caliper.
Old Jul 14, 2013 | 04:15 PM
Dealer won't care if you've tryed or not. They should take care of it, assuming dealer is worth anything
Old Jul 14, 2013 | 04:54 PM
Wert842's Avatar
I know that but you stated to at least try it. I did. I stated my results. Having my buddy from the garage come over in a bit. Hopefully we can get them free. I gave up. It isn't worth the pain and agony. Lol. I just started cleaning the wheels wells and the underside a bit.
