Brembo pins seized
What you need is penetrating fluid and you need to tap both the front and back of the pin to try and get some movement. Once it starts moving, even the slightest bit spray it good with fluid and keep working it back and forth. Coated mine in never-seize pretty good when I put them back in
Tried it. It doesn't work. Its not that easy. They aren't moving at all other than the one. They are completely seized.
Sent from my Samsung Galaxy S4 using CobaltSS
Wow, mine did the same thing, I hit 30k miles on my car and when I went to use a drift punch to punch them out, I chipped them so their was about 20% left of the pin nub to hit, i said **** it and brought it into the dealer... after i got it back, I had scour marks on the areas of the pin holes... looks like they had a rough time as well.
maintenance. its a tough life.
After doing some additional searching, Other than GMPD or CED, I was able to find the guide pins at NAPA. It is still a special order part but they are about $20 cheaper than the before mentioned places. Here is the info.
Caliper Hardware Kit - Front
Part Number: UP 83887A
Product Line: NAPA Ultra Premium Brake Parts
Looks like the car will be on Jack Stands until next weekend. :-(
^^^ you can buy cheap pins on rock auto. You may find they are too short. A lot of the cheap stuff doesnt work. and is not stainless. But then without extra maintenance in snow belt/salt road environments, it doesn't matter what material the pins are made of...
I wouldn't recommend aftermarket pins, they're usually shorter and can come out, if the pins are that hard to come out order new pins, the way I got mine out, instead of punching them out, first try putting vice grips and turn the pins, that will break them free, at least worked for me
Sent from my HTC One using CobaltSS
