Broken wire at base of seat belt
Old Apr 26, 2018 | 01:55 PM
WICobaltSS's Avatar
Hey all,
My service airbag light illuminates shortly after I start the car. Upon inspection I noticed at the base of the passenger side seat belt the blue wire is broke right at the connector (where the seat belt bracket bolts into the floor) Other than getting a whole new seat belt set up, is there a fix to this?
If not fixed, will it affect the operation of the airbag if there is a passenger?
Right now, it's more of an annoyance, but my concern is the safety of the passenger.
Thanks
Old Apr 26, 2018 | 01:59 PM
07blackg5's Avatar
Slobodan Milošević
solder the wire back together, but disconnect the battery first
Old Apr 26, 2018 | 06:06 PM
WICobaltSS's Avatar
I would, but the problem is that it separated right at the base of the connector. Is that connector somehow removable from the seat belt bracket, to where I can get in and reconnect the wire? I guess if it doesn't cause any safety issues with the air bag, I might just let it go, but I'd like to somehow reconnect the wire if possible.
Thanks
Old Apr 26, 2018 | 07:39 PM
cluelessk's Avatar
Thanks
Most connectors can be "de-pinned" and repaired. YouTube would be a good resource here.
Being an airbag connection I'm not sure if it'd work or be perfectly safe. I work as a repair planner in a body shop and it's usually remove and replace on all related airbag components.
Old Apr 27, 2018 | 06:17 AM
63 Nova SS's Avatar
Happened to mine due to my fault. I installed a new belt setup. Pretty sure that bag won't deploy because it doesn't think there is a passenger in that seat.
Old Apr 27, 2018 | 10:40 AM
WICobaltSS's Avatar
That's what I was afraid of. I'll just replace the whole assembly and not screw around with the wiring. Thanks for your help guys!
humm3r1
Apr 19, 2012 10:36 AM
06cobaltindallas
Oct 17, 2009 02:47 AM
geehumshriber
May 28, 2008 05:21 PM
snobrdrdan
Dec 19, 2007 12:20 PM
3fo893013L
Apr 5, 2006 08:16 AM
