Burning oil
Old Jul 30, 2018 | 07:02 PM
goeckeritz123's Avatar
Burning oil
Hey guys its been awhile so ive ran into some problems with the balt i ran a compression test and from cylinders 1-4 118psi 70psi 130psi 170psi I know this isnt right. I had my whole cylinder 4 spark plug filled wIth oil. Im thinking head gasket but possibly new rings just looking for input
Old Jul 30, 2018 | 07:09 PM
exninja's Avatar
spark plug well filled with oil is valve cover gasket. bad compression is likely ringland or valve seals. you can do a leakdown test to see what it is. doubtful it's the head gasket but you can test for hydrocarbons in your coolant for that.
Old Jul 31, 2018 | 12:16 PM
mrbelvedere's Avatar
valve seals have nothing to do with retaining cylinder pressure
Old Jul 31, 2018 | 12:17 PM
time to for a set of rings
Old Jul 31, 2018 | 12:28 PM
exninja's Avatar
i meant seats
Old Jul 31, 2018 | 01:30 PM
Sharkey's Avatar
agreed. oil consumption combined with low compression numbers points to bad ring sealing.
TheSandMan
Feb 4, 2013 05:27 PM
tbellazzi
Apr 20, 2012 12:26 PM
x_sgs_x
Nov 23, 2011 06:12 PM
juice3
Dec 17, 2010 10:12 AM
Gixxercobaltdriver
Nov 22, 2010 08:35 AM
