a/c not working (not a cobalt, silverado)
Old Jul 14, 2008 | 06:33 PM
jimmyfoxx's Avatar
i have a chevy 1500 and i was driving. the ac was ice cold and then all the sudden it was blowin hot air. the air compressor line is cold but no cold air. any input? thanks.
Old Jul 14, 2008 | 06:36 PM
light'bolt's Avatar
Could be the lines are freezing up, that'll stop the flow of freon or whatever they use nowadays
Old Jul 14, 2008 | 06:41 PM
jimmyfoxx's Avatar
yeah it's wont blow cold ever since that happened. so i dont think it is that. i am thing maybe i need a shot of refrigerant. it is a 99'. thanks for helping out. i know it;s a cobalt site but a lot of people here have a lot of knowledge.
Old Jul 14, 2008 | 06:50 PM
light'bolt's Avatar
I've got a silverado truck too, my air is out but up here in Iowa I really don't care to get it fixed.
Old Jul 14, 2008 | 06:53 PM
originaladrian's Avatar
just got the AC fixed in my cobalt, ur AC clutch engaging? compressor on?
Old Jul 14, 2008 | 06:54 PM
06vrss's Avatar
i know that sometimes the low pressure switches on those things go bad, compressor running?
Old Jul 14, 2008 | 07:01 PM
jimmyfoxx's Avatar
the air line is cold so i assume it is. im goign to go out and try some ****..
Old Jul 14, 2008 | 07:03 PM
if ur lines are cold to the touch ur compressor is running... thts very wierd...
Old Jul 14, 2008 | 08:25 PM
jimmyfoxx's Avatar
yeah i had the bitch running and them lines are cold as ****. im thinking the evaperator now. hmm.. so if that lines are cold, no need for a shot of r-134a.. the air in the car is a little cooler when i turn the ac at max but very little..
Old Jul 17, 2008 | 04:53 PM
jimmyfoxx's Avatar
bumb.. hot as hell outside and im going to need it this weekend
Old Jul 17, 2008 | 05:19 PM
try takingout ur cabin filter real quik, and see if tht makes a difference. is the air blowing as hard as usual?
Old Jul 17, 2008 | 07:37 PM
jimmyfoxx's Avatar
a/c lines are ice cold, compressor must be workin, i have good charge. all fuses are good. im thinkin maybe the evaporator? or some kind of sensor. i dont have any cels.
Old Jul 17, 2008 | 07:49 PM
NS06G5's Avatar
sounds almost like a blockage in the line, if it was blowing cold then all of a sudden stopped. Or it might be a kink.
Old Jul 18, 2008 | 10:47 PM
AzulitoAlero's Avatar
some older chevy's ac tends to act up when its only a pound or so low on freon. May just need a good leak test/charge at a shop, will run you 80 bucks, including a pound of freon. (if they arent raping you!!)
If thats not it, then it may be.. ****.. i forget the part name.. the vent 'doors' or something acting up. condensors dont usually go out before compressors so i dunno.
But go get a charge, it cant hurt, and includes diagnostic so you'll know whats going on. Its most likely only a pound low. GM is good about their a/c systems laasting, usually, as opposed to other car makers.
Old Jul 18, 2008 | 10:54 PM
boostedss26's Avatar
i think the word you were looking for is the blend door
KillerBee's Avatar
could have a Freon leak
Old Jul 18, 2008 | 10:58 PM
hungryhip-ccp's Avatar
my guess, i see that alot at the shop, turn the knob from hot to cold and listen for movement pass side under dash
Old Jul 19, 2008 | 01:38 AM
madmark's Avatar
i think you may have a bad mode actuator, they are pretty bad on gm models. you may be able to have it recallibrated at a gm dealer but im sure it will need to be replaced (if it)
it would be the actuator below on the passenger floor panel by the heater core
Old Apr 27, 2009 | 05:46 PM
galeblanc's Avatar
I should have posted my message here ... I am having the exact same problem with my ss/sc. I'll go take a look at the fuses. Now the problem is I installed my cold air intake. It's probably causing this problem and now I'll have to remove it before going to GM. Any other ideas?
dennis69
Sep 17, 2015 12:52 PM
shawnsseries
Sep 10, 2015 08:29 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
jthwjde
Sep 7, 2015 09:24 AM
