A/C question
Old Aug 3, 2011 | 09:37 PM
blackend's Avatar
A/C question
Hey everyone,
I have an 05 Cobalt 2.2 that I recently purchased. They lady I got it from said she thought the A/C didnt work because it needed a recharge.
So I bought a can big enough to charge the system and when I started charging it I could hear a hissing sound. I found that it is coming from the high pressure side rubber hose. It is the line on the passenger side of the engine compartment down by the condenser.
My question is is this the correct part I need to fix the problem?
Buy ACDelco Air Conditioning Compressor and Condenser Hose 15-33219 at Advance Auto Parts
Since the system obviously has no freon in it I should be able to replace this line myself. I would then have to get the system evacuated before putting the new freon in correct?
Thanks,
Brad
Old Aug 3, 2011 | 10:04 PM
blackend's Avatar
Ok well nevermind, I found out that is not the correct part and found the correct one on gmpartsdirect.com for a reasonable $41.
I do still need to know if I have to have the system evacuated/air removed before refilling.
Thanks,
Brad
Old Aug 3, 2011 | 11:53 PM
Malaclypse's Avatar
Yes. You need to have the system professionaly filled for it to work at its peak. Since its been open to the atmosphere for awhile you may also consider replacing the condensor. There's a dessicant cartridge in there that absorbs moisture. Its likely to be saturated.
It may be serviced separately but I'm not sure.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
