Camshaft position sensor! No start! Help
Old Jan 8, 2014 | 06:49 PM
NEVAREZAARON's Avatar
I have a 2005 Saturn Ion Redline 2.0L Supercharged 5speed
'Pretty much bone stock- Only has pace setter headers that's it
It had a blown head gasket so i had the head resurfaced and bought a new GM headgasket.
Everything was installed perfect. I had the car running and driving for 2 days no issues. on the next day check engine light came on and said cam position sensor correlation/performance camshaft B (something along those lines) i dont recall the exact code. So i look it up and it says that the cam position sensor is not in sync with TDC. So my best guess is that i did not install the cam shaft position sensor housing in correctly. (mind you the car runs and drives and pulls great no issues). So i decided to "re-stab" the CAM POS Sensor Housing
I even looked at the forum for additional help. before anything i pulled the spark plug out put a compression gauge hose on it then spun the engine to TDC #1 untill i got on compression stroke. I then pulled the CAM sensor housing aligned the HEX shaft to the line on the housing.
Well after all said and done i have done these steps about 35times. NO JOKE and it still WONT START UP. Just cranks and cranks!!!!
on 3 occasions I put the hex line away from the line on the housing and got it star but quickly died within 1 minute.
Any suggestions?
Old Jan 8, 2014 | 07:03 PM
I had to replace my sensor for the reason of the car not starting and the code. I just straight replaced it as it only went in one way though. Since i didnt feel like pulling my coolant hose from the back of the block the replacement sensor didnt wanna go in so i actually grinded down a corner on it a bit for clear. Not related.
Old Jan 11, 2014 | 11:02 PM
Doony's Avatar
I'm having a similar problem with my 06 cobalt 2.4. I replaced the exhaust cam sensor, sometimes it doesnt start or it cranks for a long time before it starts. :/
Old Jan 12, 2014 | 10:41 AM
thejoey12's Avatar
Be advised when I had this issue it caused me to bend a valve and blow cylinder #3 there are threads on here of how to fix it though.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 04:49 PM
cw383
Sep 30, 2015 12:41 AM
jmelton327
Sep 26, 2015 10:04 PM
