car f*$&*d
Old Nov 7, 2007 | 09:21 PM
rguti153's Avatar
car f*$&*d
so i was at a stop ...went to first then i was going to second ....everthing goes out ....i was giving it some gas ...it wouldnt go ........ my gas thingy went all down to empty ...everything shut down....try to turn it back on ....dosnt.... it just clicks .....i just took the ******* battery to autozone ..... what else can it be .....the guy at autozone said it was good but it needs some charge in it ? hopefully is nothing big ......cause **** im out of money.....damn
what do yall think ?
Old Nov 7, 2007 | 09:26 PM
Red2.4SS's Avatar
Strange, bad alternator?
Old Nov 7, 2007 | 09:27 PM
DoubleLP's Avatar
Battery. The guy at autozone does not know ****. Either that or your alternator is DOA.
rguti153's Avatar
i think thats what it is ....the alternator ........**** !!!!!!!!!!!!111
Old Nov 7, 2007 | 09:30 PM
NamedGobalt's Avatar
same thing happened in my work van... battery died.. so we recharged in and i went on my business.. just for everything to shut down and leave me stranded.. we got a new battery from autozone and installed it in my van.. and put the meter on it.. it was the alternator.. so if your battery had a little charge in it.. it's probably the alternator.
DoubleLP's Avatar
If you can get the car running again......check the voltage at the battery when it is running. If you are getting 14.4V your alternator is good and it is your battery.
To me it sounds like the battery......and not the alternator. Do you have a huge stereo in your car? If you do......upgrade to a yellow top Optima or another high end gel cell battery.
Old Nov 7, 2007 | 09:32 PM
rguti153's Avatar
nope everything is stock......it just clicks ....when i try to turn it back on .....pretty loud .....lights turns on everything .....windows go down .......it just dosnt turn on
Old Nov 7, 2007 | 09:33 PM
DoubleLP's Avatar
Well your battery is close to being dead. So either it can not hold a charge, or is not being charged.
Old Nov 7, 2007 | 10:49 PM
rguti153's Avatar
well ill see right now when i get the battery ........thanks by the way
oh k well it wasnt the battery........i guess is something worse....i was gonna ask yall when you turn your car on ....the light lock in the dash .....does it show up when you turn on the car.........cause mind it shows engine light ....the lock light ...battery brake......i think everything turns one......n it just clicks
Old Nov 8, 2007 | 12:40 AM
Red2.4SS's Avatar
All the lights illuminate when you first turn the key to let you know if they are burned out. Since its not starting the battery, low oil pressure, etc will stay on. I have a feeling its the alternator. Once the voltage drops to low in the battery the enigne will turn off, but other things may still run on the remaining power. I would test the alternator first.
Old Nov 8, 2007 | 11:17 AM
Misery5567's Avatar
Ya know...Back in the day
We'd just unhook the positive cable from the battery while the car was
running and if it shut off, we knew the alternator was bad. If it kept running
then the battery was bad.
Things are so complicated these days
Old Nov 8, 2007 | 11:19 AM
REIGN SS's Avatar
Original Hayden Fanatic
autozone should be able to test your alternator.
Old Nov 8, 2007 | 11:31 AM
GreenPurgatory's Avatar
I could have told you that it was not the battery, even is a battery goes out completely the alternator would keep it running just fine, if it is just the alternator running, it could burn out or something, but that was not the case for you cause you had just turned it on, right?
It is probably the alternator ( i doubt this, it may be a fuse), just try fixing the cheapest things first.
Old Nov 9, 2007 | 01:19 AM
rguti153's Avatar
well **** today i didnt do much for the car had to work all day tomorrow im off...so i have to figure it out ...what the hell is wrong with it ? so autozone can check the alternator if its good or not ?
Old Nov 9, 2007 | 01:26 AM
REIGN SS's Avatar
They should be able to, i know the one by my house can...
Old Nov 9, 2007 | 01:29 AM
rguti153's Avatar
thanks ...........hopefully is not something big like big big
Old Nov 9, 2007 | 01:30 AM
outtamymind's Avatar
ya but most battery checkers only check one cell of the battery. if one of the other cells isn't working properly and your using one of these battery testers it will say its ok when in actuality its not. i would take a battery from a car that you know is working from a friend or family member and put that in your vehicle and see what happens since you say your a little short on cash at the moment. then that way you can be positive if its the battery or not. i deal with testing batteries all day long at work.
Old Nov 9, 2007 | 01:35 AM
rguti153's Avatar
no ****......yeah i have my dads batter ...thats is working fine......well i need to do that to .......anything helps right now ....**** i couldnt ******* sleep last night .....stressing me out
Old Nov 9, 2007 | 01:47 AM
HackAbuse's Avatar
If your car was running and stalled it, it's definitely not the battery.
Your car doesnt need a battery to run. Only needs it to start.
Old Nov 9, 2007 | 02:14 AM
rguti153's Avatar
well the car was running switching to second ...n then it just pop ....im not sure it there was a sound or not ....i had the radio on ...but yeah just turn on ...try to turn it back on ...nope nada
Old Nov 9, 2007 | 02:23 AM
erics95se's Avatar
From what I see, the alternator is the culprit. My car died when it was just the alternator, fuel thing went empty first, then BOOM! Car fully dies while i was at a light.
also, check the connection at the starter motor for it to make sure it's nice and tight on there good..
buy :
new battery (cheapie from wal mart, just to play it safe) and an alternator from vatozone
Old Nov 9, 2007 | 02:30 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Sounds like the Alternator....
Mine went bad in my Grand Am... when I put on my blinker the stereo would go off!
But she kept running until I had to left off the gas for traffic. SO the key is going to be to keep your foot on the gas when you shift! Just don't let go of that pedal!
Hope you still have warranty!
Old Nov 9, 2007 | 02:37 AM
rguti153's Avatar
the thing is that i bought the car........at some dealership they said it had warranty on it
so i need to call the chevy dealership n ask which one it has.....**** i only have a month with the ******* car ...n it went out on me ........
Old Nov 9, 2007 | 05:39 PM
rguti153's Avatar
took it to the dealer just a while ago ....the mechanic just call me he said that ....the started might of had jam on me ......so it lock the engine some **** like that ....that it might me something big .....but is cover ..........
Old Nov 9, 2007 | 05:45 PM
cosworthzx3's Avatar
go somewhere that has a midtronics 500xl tester. It will test bat, starter, dipple diode, and alt..on load and no load....that is the correct way of doing it. Any shop with an ACDelco sign in Houston has one.
chefhhr
Oct 26, 2015 10:36 PM
vjoel2011
Oct 2, 2015 12:11 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
no_ss
Sep 18, 2015 11:03 AM
