Car hard to start
Car hard to start
Hey, guys, thanks for the you help in advance..........
Well, i have change the cam and crank position sensor, but my car takes very long to start i have to try multiple times to get it to start, I put the computer and gave me this codes
1. P0340 CAM SHAFT- SENSOR A- BANK1
2. P0341 CAM SHAFT POSITION SENSOR BANK 1, CKT
3. P0603 PCM- KEEP ALIVE MEMORY KAM.........what is this?
4. P0017 CAM/CRANK SHAFT CORRELATION SENSOR B
Has anyone had this problems.......
If you have any idea i would greatly appreciated thanks
When i bought it it had the check engine light on, and before buying it i but it on a computer obd II scanner and said the same things but i though it would only be the cam and the crank shaft sensor.........so about a week later, i bought the sensor , first the cam and then the crank, .............and the car still does the same, well, just a little better, i heard something about the computer might need to be reflash again, but am not sure...............and am out of warranties.......so that sucks.....
Getaway_Driver
Sep 8, 2015 09:41 AM
