car won't crank
Old Aug 10, 2008 | 09:05 AM
cobaltssredtint's Avatar
car won't crank
So, my friend and i put a clutch in the balt and the battery was unplug for 5 days...now after putting everything back together and every plugs connected and the battery plug back in, we tried to start the car, and it didn't crank at all.....the lights are on and when you turn the key over and press the clutch in, you can hear the starter clicking but nothing happens.....so i was wondering if anyone knew what is the problem.....
Old Aug 10, 2008 | 09:17 AM
rockSTAR_SS's Avatar
Get someone to jump you off. But let me also suggest this.
Get you a glass of water and mix it with baking soda. Take a towel with you to keep from making a mess. Open your trunk to get to the battery. Lay the towel underneath the battery, and pour the mixture on the end of the battery cables and on the battery posts. You'll probably see it fizz and bubble. Sounds like you aren't getting a good connection, so try that. It wouldn't hurt to get one of those wire terminal cleaners and run it over and thru the ends of the battery cables. Try that, charge your battery or get someone to jump you off and go for a ride. Come back, shut the car off, and try it again. Let me know
Old Aug 10, 2008 | 09:26 AM
thx for the advice....i will try it in a bit and i will let you know how it goes......
Old Aug 10, 2008 | 09:33 AM
Alright bro. It may be just as easy to take the battery out of the car. The baking soda mixture is a strong base that neutralizes the battery acid, so i would take it out of the car. If you don't have a wire brush or anything just take an old tooth brush and brush the ends of the cables and battery posts real good. Do this repeatedly until nothing fizzes anymore. Just don't get the baking soda in your actual battery acid reservoir...
If you want to avoid this in the future, go to your local parts store and buy some of the red and green things that slide over the battery posts. They usually help a lot.
Old Aug 10, 2008 | 10:04 AM
also , its not like my car is old, its only 7 months old....so the battery is not that old.....but as soon as i get the chance to go home and check on the car , i will do what you said and we will see.......
Old Aug 10, 2008 | 10:07 AM
The car doesn't have to be old for battery acid to start eating at your cables and posts. In fact, I had a brand new battery put in my car and about 2 months later this problem occured. I'm not really sure why, but yeah let me know. BTW, what kind of clutch did you install?
Old Aug 10, 2008 | 10:15 AM
papasmurf's Avatar
do our cars have the clutch safety thingamajiger? I know I have had friend who couldnt get his truck to start because there was some kinda safety switch thingy on the clutch so that the car would start.
Old Aug 10, 2008 | 10:16 AM
Smarty Art's Avatar
Check the fuses. There are 2 connectors that plug into the tranny. Double check.
Old Aug 10, 2008 | 10:47 AM
i put a stock clutch on, i know i should have bought an aftermarket clutch like centerforce dfx but that for the end of the year when i get more money saved up...i was kind of in need of a clutch for the moment thats why i went with the stock clutch for now and i got a good deal on it...
yea i made sure that they were plugged in when i was done putting everything back together.....i will check my fuses..thx for the help...i will let you know how it turned out
Last edited by cobaltssredtint; Aug 10, 2008 at 10:47 AM. Reason: Automerged Doublepost
Old Aug 10, 2008 | 06:59 PM
ok, i checked it and it was none of that , it says something about the camshaft position sensor, i don't know where thats located at...if anyone knows , plz tell me .....
Old Aug 10, 2008 | 07:19 PM
silverfae7's Avatar
The cam sensor is almost right above the thermostat/upper radiator hose. I can send you a picture if you need one.
Old Aug 10, 2008 | 07:34 PM
It's on the very back of the damn motor. A damn pain to get to.
Old Aug 10, 2008 | 07:40 PM
cobalt_driver's Avatar
when my clutch was changed my buddy and i did it in about 2 weeks. we were really busy. but in the process between random people "helping" i had a solenoid on the starter busted, a couple blown relays, fuses missing, etc...just stupid bullshit. im not saying you did it incorrectly however just double check things. i had the same problem but mine was the starter. are you sure its engaging with the flywheel?
Old Aug 10, 2008 | 10:00 PM
yea , it would be helpful if you could send me a pic
i mean what would make it not engaging with the flywheel??? i used a scan from autozone and it read a p something code and it says the camshaft sensor is not hook up....now i have been loking for that damn sensor.....and where in the back of the engine is it at??
the code was P0365
Last edited by cobaltssredtint; Aug 10, 2008 at 10:00 PM. Reason: Automerged Doublepost
Old Aug 10, 2008 | 10:18 PM
Coblasts's Avatar
Crankshaft Position (CKP) Sensor
located- In front of the engine above the starter
Old Aug 10, 2008 | 10:39 PM
lsjion's Avatar
make sure you dont have the pcm connector and the throttle body connector swapped. Same exact thing happened to me after my engine swap.
Old Aug 11, 2008 | 03:13 AM
it was just a relay problem......it had nothing to do with the CKP
Turbo Johnny
Feb 21, 2019 09:41 AM
How to Guide
57
Oct 15, 2015 11:56 AM
bobbob160
Sep 15, 2015 11:31 PM
Adam144
Sep 3, 2015 07:48 PM
