CEL light. running lean. what to do.
Old Feb 28, 2009 | 05:30 PM
greygoose08's Avatar
i installed gm 42# injectors. along with zzp 3" pulley and hub. now i have a CEL light on and had an appointment at gm today for a antenna bracket that was broke. the foound out about the stuff i did to it and said w/e they usually do. but neway. they said that the light is on because the injectors are not getting enough fuel or that is at least what the pcm is thinking. but i got the pcm from zzp and had it tuned to the 42 pound injectors. so basically im running realy lean and its trying to give it more fuel. so do you guys have anythning i can do to correct this and get rid of the light? THanks
Old Feb 28, 2009 | 06:11 PM
Coblasts's Avatar
Disconnect your battery for 10 to 20 min to reset the fuel tables(I think thats what there called) and reset the code and see what happens.
Old Feb 28, 2009 | 06:20 PM
light'bolt's Avatar
could be the zzp tune didn't take into account the exhaust and airbox mod. MAF calibrating may be off? Just a guess though...
Old Mar 1, 2009 | 09:26 AM
Coblasts's Avatar
Get a hold of zzp and it says on there web site that they will help you with tweaking the tune for you.
Old Mar 1, 2009 | 10:10 AM
Rodimus_Prime's Avatar
yup sounds like a MAF calibration issue, which a dealer most likely wont help you with they will simply tell you to remove the aftermarket parts or blame them
turbochargedss2012
Sep 20, 2023 12:17 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
dieGone
Oct 1, 2015 06:27 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
