CEL P2135 Help
Old Aug 30, 2011 | 01:00 AM
Murdered SS's Avatar
CEL P2135 Help
So just to fill you guy's i took the car a month ago to the dealership for the fuel pump and powersteering motore recall. Ever since the the car has been messed up first car kept going into Engine reduce power, battery kept drain, and car started to shut down and jerking on me. Took it back in the dealer two weeks later said my battery one cell is done so need a new battery but battery was fine before. The engine reduce and the jerking and shut down idk but the installed a new PCM. After that got the car back told me i need a new battery gonna get one tomorow. After getting then car back drove home it like right up the street from the dealer parked the car sat for about 3hr till i had to go to work. Started the car cel went off took it to oriely's they hook it up code P2135 Throttle Position (TP) Sensor 1-2 Correlation -PCM and
P0315 Crankshaft Position (CKP) System Variation Not Learned -PCM. So the guy deleted code are started fine went to work but engine reduce power keeps popping up. today it went off twice and it now only the P2135 Throttle Position (TP) Sensor 1-2 Correlation -PCM . Sorry for the rant but does anyone know how to fix this or should i just take it back to the dealer? which I am tired of the dealer ******* **** up help please.
Old Aug 30, 2011 | 01:14 AM
Bump Sorry should have searched it first lol. I'm not the only one with this problem from what i see.
Old Aug 30, 2011 | 11:24 AM
Coblasts's Avatar
Go out and check to make sure the pcm connectors are clipped in on the pcm properly.
THe crank learn should of been done by them when they installed the new pcm,ask them if they did it.And if they did it probably didnt work properly and have them do it again.
The pcm change could be the source of all the problems and not having it calibrated to the car properly.
Just found this
Important: The Crankshaft Position (CKP) System Variation Learn Procedure may have to be repeated up to 5 times before the procedure is learned for various reasons.
Old Aug 31, 2011 | 01:11 AM
Thanks for the info the only cel going off now though is P2135 Throttle Position (TP) Sensor 1-2 Correlation -PCM.
But from what i read it could be alot of thing also just got a new interstate battery today so we'll see what happens.
Old Sep 2, 2011 | 12:02 AM
Dealership called today for a courtesy call told them whats going on. So now have to take the car in again sometime this week. Hope they dont have to keep it again cause i'm gonna be screwed.
turbochargedss2012
Sep 20, 2023 12:17 PM
Dustin24
47
Feb 12, 2016 04:10 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
Dustonian131
Sep 23, 2015 08:03 PM
