Cel p2195
Old Apr 12, 2012 | 09:49 AM
YesYestotheSS's Avatar
Cel p2195
I already checked the sticky for the list of CELs and this one wasnt listed.
I got this code and it was for bank 1 sensor 1 which is my front o2. the code said the ecu sensed the sensor was receiving low voltage; heater circuit failure (or something very similar along those lines)
i changed the o2 sensor with the exact same sensor stock ones come with. A day later, CEL comes back on. I reset my ECU, CEL goes off. Two days later (today) it comes back on.
Help lol?
Old Apr 12, 2012 | 10:26 AM
bluebalt07's Avatar
Well if it says it getting low voltage, try to unplug it and get a volt meter to test the connection and see what kind of voltage it's getting
Old Apr 12, 2012 | 11:58 AM
Do you know what the voltage should be?
Old Apr 12, 2012 | 06:41 PM
bluebalt07's Avatar
It depends on what wire you test. The power wire should be getting 12 volts but there is probably also a reference wire that gets 0-5v depending on what the sensor is reading
Old Apr 12, 2012 | 07:17 PM
johnccc's Avatar
You can get all this information accurately and a lot more easily using a scan tool.
I have one and I got the o2 heater circuit error, then replaced the sensor, I get the same result as your getting, sometimes it takes upto 100 miles before the CEL comes on again, sometimes it returns fast.
As I've been investigating, so far I believe it may be a clogged cat con in my case, I think its making the sensor inoperable, so I will be changing out the cat con soon, I know its bad because I get the cat efficiency code at times too.
If you o2 sensor is not connected you should get 4.60V output (ref) and it stays there and not fluctuate. If its working you will get anywhere between 1V and 9V fluctuating.
Old Apr 13, 2012 | 05:47 PM
Coblasts's Avatar
Another thing to check is your PCM connections are good.(connectors seated good)
Also any shorting of wires to ground or themselves,follow them back and take a good look where the bundles may be rubbing.
Old Apr 13, 2012 | 09:38 PM
alright, i went to a friend he suggested to check the wiring, i know for the fact that the sensor is not bad and its wiring isnt bad. and i know the connector is in good clean contact.
im gonna undo my bundles and see if theres like a hair like split in one of the four wires in the 02 sensor
Old Apr 13, 2012 | 09:40 PM
i know my cat isnt clogged, its a new high flow cat so that shouldnt be the problem
turbochargedss2012
Sep 20, 2023 12:17 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
Dustin24
47
Feb 12, 2016 04:10 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
