CEL on solid!
Old Jul 3, 2006 | 08:51 PM
mi6_'s Avatar
Question CEL on solid!
Hope someone has a suggestion.
Drove to work today, parked the car. Got in it to leave, started it up and it threw a CEL. Shut it off, re-started, still threw a code. Seemed to run/drive fine so I took it home. Thought maybe it was the gas cap. I checked that. It was a little loose, so I tightened it, and drove around for a while, but the light didn't clear. The owners manual says it may take some driving until it clears, but mine didn't. I drove for like 10 minutes, so I am assuming that is not the problem.
Otherwise, the idle seems a tad rougher than usual, but it may just be my imagination. Can't see anything loose or disconected in the engine bay. The car did not get wet. It was a warm +30 day here in Edmonton. It has run much longer in that heat before. Coolant temp was well within normal too.
I'll have to call my dealer. I have some very important running around to do tomorrow, so I hope the car doesn't die on me.
If anyone has some other suggestions that I can try, please let me know!
Thanks!
Dustin
Old Jul 3, 2006 | 10:32 PM
jokieman's Avatar
without a code i don't think anyone can help you. Get a code reader or have someone pull the code.
Old Jul 3, 2006 | 10:36 PM
alleycat58's Avatar
Exactly, anything with no symptoms and no trouble code could be anything. Example: my car threw two codes, lighting short and XM failure. No symptoms, no lighing problems, no XM problems. No way to know what they were without a reader......
Old Jul 4, 2006 | 07:00 PM
mi6_'s Avatar
It's going out to the dealer tomorrow. They said that even if it was the gas cap, they will nead to clear the code. The manual is incorrect in stating that the code will clear.
I was just hoping that it was something simple that I was missing. I am sure it is nothing major. Oil, coolant, belts and everything else are fine. I don't hear any knocks or anything else wrong, so hopefully it was either gas cap or just a fault sensor.
turbochargedss2012
Sep 20, 2023 12:17 PM
ricklovin93
Aug 27, 2016 06:35 PM
footballplaya3k
Sep 30, 2015 09:39 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
