center console help
Old Mar 18, 2011 | 09:08 PM
center console help
How does it come apart? I want to install shifter bushings but need to take it apart first to get to them. Any help is appreciated
Old Mar 18, 2011 | 09:14 PM
SS_NH's Avatar
I think there is a screw on either side towards the back, and two holding the piece where the shifter is.
Other than that... just pull lol.
Old Mar 18, 2011 | 10:07 PM
That's It? Damn! Nice!
Old Mar 18, 2011 | 10:08 PM
SS_NH's Avatar
weeeell, dont just yank.
I'd look for more screws to be sure.
But thats all I remember. four screws, two cig lighters and the shift boot is it besides the clips.
Old Mar 19, 2011 | 11:03 AM
Gonna attempt
Old Mar 19, 2011 | 11:17 AM
sternerG85SC's Avatar
i would recommend taking the entire center consol apart when installin the upgraded aluminum base bushings. i attempted to install the base bushings with the main huge center console still installed (main piece everything clips onto) and ended up droping a base bushing under the carpet. had to remove the main center part to retrieve it lol. but its alot easier and you have more room to work with. i believe the main center part has about 11 small bolts holding it down. the old bushings are pretty simple to remove. use a screw driver to pry out the metal washer/sleeve from the top then just push out the rubber bushing. replace with the upgraded and put everything back together.
Old Mar 19, 2011 | 01:59 PM
I did what sterner said and removed the whole center piece. Deffinitely helped with my gorilla size hands.
Wasn't hard just felt like the screws were. 9 miles long
Solaris99
28
Mar 15, 2017 01:22 PM
nathan112i
Sep 30, 2015 07:12 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
metroplex
Sep 27, 2015 07:48 AM
