Chain Guide Bolt Damage ?
Old Mar 24, 2013 | 03:56 PM
SIKPUP's Avatar
My son has driven his 06 Cobalt SS/SC to 165,000 miles . The timing chain finally jumped and bent all 8 intake valves. My problem is both bolts on the black chain guide have broken , and where the lower timing chain guide was mounted it has worn a groove in the aluminum mounting boss .. like the one in this thread ..
https://www.cobaltss.net/forums/2-0l...ailure-290968/
ours is a little more chewed up then the one in the pic !
How is the best way to repair this with the engine still in the car ?
What has anyone done ?
Thanks, SIKPUP
Old Mar 24, 2013 | 07:31 PM
mrbelvedere's Avatar
post a pic up of the damage
Old Mar 24, 2013 | 07:47 PM
SIKPUP's Avatar
I haven't learned this site yet . I was able to get it as a signature picture in my profile. Sill working on how to post a pic. Picture shown is our block !
Thanks , SIKPUP
Old Mar 24, 2013 | 07:57 PM
buildmeanempire's Avatar
Create a photobucket account and put the pics on there. Copy the IMG line and post up here.
Old Mar 24, 2013 | 08:32 PM
SIKPUP's Avatar
Old Mar 24, 2013 | 08:52 PM
SIKPUP's Avatar
Old Mar 24, 2013 | 08:56 PM
SIKPUP's Avatar
Old Mar 24, 2013 | 09:00 PM
SIKPUP's Avatar
[IMG][/IMG]
Old Mar 24, 2013 | 09:27 PM
JapEatr's Avatar
South Central *********
Grind it flush then use a washer to back space the black guide forward the amount you ground flush.
New bolt with loctite also
Old Mar 25, 2013 | 09:42 AM
do what jap said but look down the chain from the valve cover to make sure the chain runs center of the chain guide
Old Mar 25, 2013 | 10:21 AM
JapEatr's Avatar
This^^
Also in order to get the thickness of the washer just right you may need to do some additional fitment
I would run a tap thru the threads to chase it as well
Old Mar 25, 2013 | 11:58 AM
SIKPUP's Avatar
My concern is that it is worn a lot deeper then it looks ! I don't think the stock bolt will be threaded deep enough to catch enough threads. I may need to find a stud with a spacer that fits to have the adjustability to line the guide up with the chain. Has anyone used some kind of aluminum epoxy to fill that "pothole" back to original surface level ?
Old Mar 25, 2013 | 12:32 PM
JapEatr's Avatar
qwick steel will work. you can also drill and retap it deeper as well
Old Mar 25, 2013 | 05:07 PM
**** quick steel its a half ass fix that can break out easily
either get a used engine or pull that engine and remove the broken and get the damage welded up flattened out and tapped
Old Mar 25, 2013 | 05:11 PM
JapEatr's Avatar
truth
Old Mar 25, 2013 | 07:55 PM
Tjolley's Avatar
The shoulder on the guide bolts r 11.5mm a really odd size.
Buy yourself a 12mm hand reamer. Then a 12mm sholder bolt with a m6x1.00 thread on it with the proper threat length the tale up the difference.
Old Mar 25, 2013 | 09:06 PM
MrSlickSter06SS's Avatar
True story bud, just replaced my motor for the same situation... I wouldn't cut corners Mr. B is absolutely correct.. Good luck sir.
Old Mar 25, 2013 | 09:53 PM
JapEatr's Avatar
B4 u scrap the block try to grind it flush
Old Mar 25, 2013 | 10:16 PM
SIKPUP's Avatar
First I'm going to lower the engine cradle on the pass side, and if I need more room I will trim the pinch weld. I'm going to drill the broken bolt out with left handed bits. To see where I'm at. Has anybody TIG welded the block ? With it in the car ? Can a longer stainless steel bolt be threaded into the hole and be tigged around it ? retapped and ground smooth ?
All opinions welcome ! Only have one good chance to fix it ? Want to figure the best option before doing something non repairable....
Thanks, SIKPUP
Old Mar 25, 2013 | 10:26 PM
JapEatr's Avatar
I have tigged the timing cover while on the car, not the block itself
I think u have better luck with grinding it smooth and backspacing the guide, drill and tap to M6 x 1.25
Old Mar 26, 2013 | 12:04 AM
You know it is pretty fuked gm hooks us up with bolts that snap from timing chain guide rails.. Tbh I haven't heard of any other cars with this issue.. Only the cobalt.. Am I mistaking lol??
Old Mar 26, 2013 | 12:20 AM
Thanks, SIKPUP
the easiest way to get the broken bolt out it to weld a nut to the broken off bolt and unscrew
Old Apr 23, 2016 | 08:35 PM
Parzival's Avatar
Same problem
So my 2006 Cobalt ss 2.0 Lsj died on me a few days ago. Opened up the front cover cause there was a bunch of timing codes and same thing. Chain guide rail is broken. The upper bolt head, lower bolt and piece of rail are probably in the oil pan. Lower bolt hole boss is hallowed out and I need to extract the upper ones bolt shaft. Was wondering which is the best route to take, buy a new engine or try to repair?
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Trav3480
Sep 28, 2015 02:46 PM
