Check engine - 2 codes
Old Mar 18, 2015 | 02:01 PM
EWC88's Avatar
Hey guys, my girlfriends 08 cobalt (non ss) check engine light came on lastnight. I got it scanned today and the codes it through was P0411 and P2440. Car doesn't feel any different or anything. When I googled I saw some people saying when they had those codes the car wouldn't start. I'm not having this issue, so confused what it can be, any help I appreciate guy!
Old Mar 18, 2015 | 02:09 PM
umrdyldo's Avatar
Secondary Air Injection system
Could be Fuse, Relay, Pump or check valve.
Good luck, sorry i don't know much about that system.
Shouldn't hamper performance I don't think,
Old Mar 18, 2015 | 03:02 PM
EWC88's Avatar
Yea that's what I just found. Doing more googling I see someone said their valve was stuck closed which threw the code and that if the valve was closed shut and can't open engine would run fine still. I just wanna make sure this all sounds right. But since I got both codes I don't know if it's just valve or if it's pump, and at $140 each I'd like to figure which one lol.
Old Mar 18, 2015 | 04:20 PM
umrdyldo's Avatar
Shot in the dark, but there was a time when people were able to remove the air injection system and either get the dealer to overwrite the codes with a non SAI car tune or someone use HP Tuners to get rid of the codes.
Old Mar 18, 2015 | 10:33 PM
EWC88's Avatar
My buddy was telling me it could be a leak in hose, or it's the valve or pump. I just gotta figure out what it is...
Old Mar 19, 2015 | 10:11 AM
scagnetti76's Avatar
Start with the pump solenoid relay. P2440 is for short in solenoid circuit. Easy place to start, if the relay is stuck the ECM may be seeing voltage when its not expecting it. And you're correct, wont cause any issues unless you have to pass an emissions test. The pump just helps the cat get to temp faster on start up.
Old Mar 19, 2015 | 10:51 AM
EWC88's Avatar
Ok I'll take a look at her fuse box to see which one I need and get it and try that out first, I'll report back after.
Do clear code to make sure relay work can I disconnect battery?
Old Mar 19, 2015 | 02:03 PM
umrdyldo's Avatar
Yes disconnect battery for like 15 minutes.
Old Mar 25, 2015 | 11:53 AM
EWC88's Avatar
Can't find her user manual, and when looking at fuse box I can't seem to find which one is pump solenoid relay. Would it be the one marked Cool Fan 1, or Cool Fan 2?
Old Mar 25, 2015 | 01:01 PM
umrdyldo's Avatar
On most GM cars the 30 amp fuse for the SAI system is not in the under hood fuse box or the under dash box. I'm searching for it's location now.
Old Mar 25, 2015 | 01:49 PM
EWC88's Avatar
Oh wow that's news to me lol, yea if you find out that be awesome, I'm trying Google now.
Old Mar 25, 2015 | 04:50 PM
EWC88's Avatar
I'm only finding through Internet two fuse boxes which are the ones you said it wouldn't be located. So if you figure where it's out please let me know because I'm lost.
Old Mar 25, 2015 | 05:35 PM
umrdyldo's Avatar
I can't either but looking at the diagram nothing in either of the fuse boxes seems to match.
Check all of the wiring to and from the SAI pump. It should have a fuse somewhere.
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
DocSvensk
Sep 27, 2015 02:24 PM
