Check Gas Cap?
Old Dec 17, 2008 | 11:05 PM
NinjaHampster's Avatar
Check Gas Cap?
i keep getting this message. it started about 3 days ago and everyday since then it just randomly comes on. i get out and check it and its still tight. um...
****EDIT****
bad purge valve for the evap system
Old Dec 17, 2008 | 11:06 PM
XM15's Avatar
Vacuum leak?
car runs fine
Old Dec 17, 2008 | 11:08 PM
Gunney_07's Avatar
no evap leak is what that causes not vacuum, has it thrown a code yet? if so what code?
Old Dec 17, 2008 | 11:09 PM
no codes, just a *ding ding* check gas cap
Old Dec 17, 2008 | 11:13 PM
Gunney_07's Avatar
the only real reason you have to make sure its tight is because the evap system detects it as a evap leak and genrealy throws code but being that these are "newer" cars maybe it can tell the differnce between a acual leak in the system and an open gas cap?
Sharkey's Avatar
if its tight and still does it it needs a new gas cap. if your under warrenty take it to the dealer, they will replace it for you
Old Dec 17, 2008 | 11:16 PM
where is the evap and how do i check it?
Old Dec 17, 2008 | 11:25 PM
ItalianJoe1's Avatar
All over the car, its the system that pressurizes the fuel tank to check for fuel vapor leaks.
As posted above, most likely a bad gas cap. If that doesn't fix it, there is a leak in the lines somewhere. Have the dealer fix it, should be covered under 8/80 federal emissions warranty.
Old Dec 17, 2008 | 11:29 PM
sweet alright thanks guys
Old Dec 17, 2008 | 11:34 PM
Doubletg13's Avatar
same thing happened to me..it was under warranty and i took it to the dealer 2 times..they did a smoke test to check for leaks..nothing the first time and finally it leaked the 2nd time and they replaced it for free
Old Jan 16, 2009 | 05:09 PM
Hockeyman's Avatar
Bumping a thread here, i'm having the same thing happen to me on my 07 ss/sc. No codes just the gas cap message comes on every once in a while. OP, did you take it to the dealer yet? Do they need to see the message before they replace the gas cap?
Old Jan 19, 2009 | 04:29 PM
im going tomorrow i have been busy. but i have an appointment set. i just got a check engine light and its saying large Evap leak now. so there going to fix that too
Old Jan 20, 2009 | 06:08 PM
was a bad purge valve and yes its covered under warranty
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
