Check Gas Cap?
Check Gas Cap?
i keep getting this message. it started about 3 days ago and everyday since then it just randomly comes on. i get out and check it and its still tight. um...
****EDIT****
bad purge valve for the evap system
****EDIT****
the only real reason you have to make sure its tight is because the evap system detects it as a evap leak and genrealy throws code but being that these are "newer" cars maybe it can tell the differnce between a acual leak in the system and an open gas cap?
All over the car, its the system that pressurizes the fuel tank to check for fuel vapor leaks.
As posted above, most likely a bad gas cap. If that doesn't fix it, there is a leak in the lines somewhere. Have the dealer fix it, should be covered under 8/80 federal emissions warranty.
same thing happened to me..it was under warranty and i took it to the dealer 2 times..they did a smoke test to check for leaks..nothing the first time and finally it leaked the 2nd time and they replaced it for free
Bumping a thread here, i'm having the same thing happen to me on my 07 ss/sc. No codes just the gas cap message comes on every once in a while. OP, did you take it to the dealer yet? Do they need to see the message before they replace the gas cap?
roth
Sep 26, 2015 12:16 PM
