Check gas cap?
Old 12-05-2011, 08:45 AM
2.2CobaltLS's Avatar
Check gas cap?
i got a 06 cobalt ls 108k on it just changed the motor oil in it and put winter tires on er n it says check gas cap for some reason i dont know why... and everytime i turn my wheel clockwise i can hear tire scraping kinda sounding thing... same size tires that came off the car..
Old 12-05-2011, 08:52 AM
umrdyldo's Avatar
well first things first
Did you check the gas cap?
Can also be an issue in the evap system.
I don't remember if the 2.2 has an evap purge selenoid on the manifold.
Old 12-05-2011, 08:56 AM
yes i checked the gas cap
Old 12-05-2011, 09:00 AM
umrdyldo's Avatar
Well on most Cobalts this will be one of the following:
Bad gas cap
Gas cap not tight (3 clicks minimum)
Evap purge selenoid by the engine
Evap vent valve by the gas tank.
Are you getting any check engine lights? Codes?
Old 12-05-2011, 09:09 AM
OrngBalt's Avatar
If you ran it with a loose gas cap. Tightening it wont get rid of the CEL. fix the cap, then clear the cel, then start it up again.
Old 12-05-2011, 09:37 AM
umrdyldo's Avatar
or it takes a few cycles for it to go away.
Old 12-05-2011, 02:15 PM
Chevrolet Cust Svc's Avatar
I see you've already gotten great feedback on this post. If you were to work with a dealership in the future on this or another vehicle concern and wanted assistance in the process, please don't hesitate to send me a private message with more information.
Best,
Sarah
GM Customer Service
Old 03-31-2014, 05:59 AM
DABOY's Avatar
same problem here, GAS CAP... needs helpppppp
Old 03-31-2014, 09:26 AM
umrdyldo's Avatar
So you checked all of these? Start with evap purge selenoid.
Bad gas cap
Old 04-11-2015, 11:56 AM
XStylus's Avatar
Bad gas cap
Sorry to necropost, but...
I've replaced the gas cap, the purge solenoid on the engine, and the evap valve by the gas tank. I'm still getting the "Check gas cap" warning.
Is there anything else it could be?
Old 04-11-2015, 02:49 PM
tomj77's Avatar
Did u clear the code and see if it comes back? Or are u just waiting for it to clear itself?
Old 04-14-2015, 03:13 AM
XStylus's Avatar
There's no point in clearing the code when the "Check Gas Cap" error message keeps coming back, causing it to throw the code again.
The "Check Gas Cap" warning seems to come up roughly when I'm at 3/4ths of a tank of fuel.
What other parts do I need to throw at this problem? Maybe a worn or cracked hose somewhere?
Old 04-14-2015, 12:25 PM
Viperoni's Avatar
I keep on getting the Check Gas Cap message on my IRL, and I've replaced the purge solenoid underhood and vent valve by the gas tank.
I seem to get it when the gas levels drops from a full tank to 1/2 to 3/4 left.
RaginChopsuey
10-27-2015 01:27 PM
biniecki
10-25-2015 02:23 PM
DocSvensk
09-27-2015 02:24 PM
Adiaz1ss
09-26-2015 11:51 PM
roth
09-26-2015 12:16 PM
Quick Reply: Check gas cap?
