Check Gas Cap??? wth?
Old Oct 28, 2009 | 07:28 PM
AdamB89's Avatar
Thumbs down Check Gas Cap??? wth?
okay now im not that retarded i know how to screw a gas cap on but anyway...so i was just drivin around the other day and it said check gas cap..
thats the second time it said that in the last week but this time it threw a CEL...and it said it again today
any idea's on whats wrong cuz im gonna feel like a retard taking my car to the dealer saying my car said to check the gas cap lmfao
Old Oct 28, 2009 | 07:33 PM
WVsuperSS's Avatar
when my friend bought his silverado they told him not to click it more than twice or it would throw that CEL on... idk though
glen229's Avatar
i get this once a week, no CEL tho
Old Oct 28, 2009 | 07:34 PM
BLAZIN07SS's Avatar
I'm too JDM for you
EVAP leak. take it to the dealer
Old Oct 28, 2009 | 07:35 PM
TurboTommy's Avatar
do you have a TB spacer?
Old Oct 28, 2009 | 07:42 PM
AdamB89's Avatar
no i dont...
Old Oct 28, 2009 | 07:43 PM
stacy_dammit's Avatar
This sounds similar. Check the seal on the gas cap. If the rubber seal is cracked or not there than thats what might be wrong. You cant have any leaks in there. happend to my moms car. Bought a new cap and CEL goes away. If not, then i dont know what else,
Old Oct 28, 2009 | 07:45 PM
glen229's Avatar
i swapped mine iwht my dads torrents, still get the same check gas cap **** , again no CEL tho
Old Oct 29, 2009 | 12:49 PM
DaBuzzard's Avatar
X2
The "Check Gas Cap" message is telling you that the system is detecting too much air flow through the evap system - could be a loose cap, bad seal on the cap, leak in the fuel filler hose, leaking hose on the evap system, purge valve stuck open.......
If the cap is on and the seal is ok, my money is on the purge valve
And it should fall under the emission system warranty
Old Oct 29, 2009 | 12:52 PM
ShortStack's Avatar
I just reopened mine and closed it.
Old Oct 29, 2009 | 04:48 PM
Hockeyman's Avatar
I used to get that message too, and the p0455 code. Apparently there is a recall for 07s, the message and code come up but there is no evap leak. The solution is a reflash, but if you are tuned it will erase it. I just deal with it now.
Old Oct 29, 2009 | 11:16 PM
Alwaystcb's Avatar
Please don't over look this.....I had this same problem with my 06 sc and $400.00 later it is now fixed.....I was throwing all kinds of codes but it started with the gas cap code coming on just every now and then. If you have replace the gas cap then start looking at the evap system. Where you are going to notice this the most is when you get gas. When you get gas does it not want to idle?
Old Oct 29, 2009 | 11:26 PM
revolution607@yahoo.'s Avatar
x2
had the same problem
Old Oct 30, 2009 | 04:36 PM
Hockeyman's Avatar
I replaced the gas cap and the dealer did a smoke test. They didn't find any leaks whatsoever. I get gas at Shell. I throw the p0455 code maybe once or twice a month if that. Haven't got the check gas cap message in a long time though.
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
yellow dragon
Sep 28, 2015 09:49 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
