chirping noise from engine
Old Nov 30, 2006 | 07:37 PM
beerbaron105's Avatar
cobalt makes a chirping noise from the enginebay upon starting it cold for about 60 seconds - 2 minutes then it goes away i guess as the engine warms up a tad, only noticed it recently with the colder mornings but never last winter.
Old Nov 30, 2006 | 07:42 PM
NJHK's Avatar
Baby chickens give you 5 horsepower...duh lol
Old Nov 30, 2006 | 07:43 PM
D4u2s0t's Avatar
things probably just need to warm up... when parts get very cold, they shrink a little bit and get tight... (I was in the pool!!) seinfeld reference...
Old Nov 30, 2006 | 07:44 PM
NJHK's Avatar
Did you ever listen to where in your engine bay it's coming from while it happends?
im just hoping its a squeaky belt and not the supercharger rotors chattering, although i wouldnt exactly know what that sounds like.
yea but i cant narrow it down
Old Nov 30, 2006 | 07:45 PM
NJHK's Avatar
Yeah I was thinking that too.
(love Seinfeld too lol)
Old Nov 30, 2006 | 07:53 PM
D4u2s0t's Avatar
all time favorite show!!
back on topic, as long as it stops once the car warms up, i can pretty much guarantee that's what it is... it's not uncommon when it's cold out, in any car
Old Nov 30, 2006 | 09:18 PM
LandonElf's Avatar
I actualy have a chirp under my passenger seat (i have g85) and I CANT FIGURE OUT WHAT IT IS!!! I think it may be the passenger seat belt floor bolt rubbing but i have no idea what do to about it.
Old Dec 1, 2006 | 06:55 AM
i just wanted to add, its not a belt squealing type of noise, ive heard those before on other cars, its a chirp that runs in tune with the rpm of the engine (chirp,chirp,chirp,chirp,chirp,chirp - if u said that outloud one after the other, thats the sound)
im just worried because i heard stories of rotors hitting the housing
Old Jul 14, 2007 | 05:11 PM
SLMDNV's Avatar
Bringing back this thread from the dead, Was this problem ever resolved?? Mine is doing the same thing now. Brought it to the dealer and they thought it was belt squeak, so they put a new belt on. That didn't change anything it still does it everytime I start it and lasts for a few minutes. It is really annoying and it definately isn't supposed to sound like that. I narrowed down the noise to the passenger side of the engine compartment somewhere in the rear so it is not the supercharger. Anybody have any ideas????
Old Jul 14, 2007 | 05:59 PM
Coblasts's Avatar
Take the belt off and in the morning when its cold try spinning and feelling by hand the idler pulley, super charger and air con pulley.
if you have stage 2 the charger pulley could be slightly out of line causing the chirp until the belt heats up.
Old Jul 15, 2007 | 07:08 PM
SLMDNV's Avatar
Well, I took the belt off and spun all of the pulleys by hand and none of them make any noise and they all spin freely like they should.
From what it sounds like, the noise is coming from the back of the engine where the water pump is. Also forgot to mention, this noise happens even when engine is warm, up to about 155 degrees. If it is at running temp (180) it wont do it. Its really weird, I can go into a store for like 10-15 minutes, come back out and it sounds worse than in the morning when the engine is really cold.
Im just afraid that my dealer is going to say that theres nothing wrong with it and send me on my way with a janky car that makes funny noises.
Old Jul 15, 2007 | 07:23 PM
RaineMan's Avatar
I believe this "chirping" noise is the belt tensioner...
My 2001 Ford Ranger had a horrible chirping under the hood... sounded like a couple of birds under there... dealer replaced the belt twice... that would solve the issue for a week or so... until the belt got good and broken in. On the 3rd return for the problem they properly identified it as a faulty belt tensioner and replaced it... noise went away.
Now I know the LSJ is totally different from a Ford 4.0 V6... but both have belt tensioners... so check there and see what you find. Try squirting a bit of WD40 on the back of the tensioner pulley and see if it goes away.
Old Jul 15, 2007 | 07:31 PM
SLMDNV's Avatar
It is not coming from the pulleys. The noise is from the rear of the engine away from the pulleys.
Old Jul 15, 2007 | 07:33 PM
RaineMan's Avatar
hmm... there isn't much in the rear of the engine bay... exhaust manifold...
does the car drive fine? maybe a small vac. leak?
Old Jul 15, 2007 | 07:47 PM
SLMDNV's Avatar
Yeah, car runs great. It could possibly be the exhaust manifold. I am bringing it back to the dealer to let them decide what it is since I still have warranty left. I am actually surprised that they warrantied the belt since I have stage II and installed myself.
Old Jul 18, 2007 | 04:06 PM
SLMDNV's Avatar
Well, the dealer found the problem: The gasket between the ex. manifold and the downpipe was bad. They replaced and no more noise...
Old Jul 18, 2007 | 05:25 PM
Master Chief's Avatar
hmmmm well that is my exact problem with the chip as well and they ordered me an exhaust gasket and that might fix the problem
lol yay
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DANRICKARD
Oct 1, 2015 12:08 AM
