Clock Spring Help
Clock Spring Help
Do you usually lose all of your steering features, when your clock spring gets overextended? I changed my rack and pinion, and the steering wheel was moved. After I got everything back together, the AB light came on. Everything on the wheel worked fine. I just had that stupid light on.
I replaced the clock spring tonight, and got it all back together, but the damn light is still on! Do you have to do something to reset it, or was the clock spring I got bad? All the steering wheel features work fine.
Generally restraint system DTC's have to be cleared manually with a scan tool. Not positive but most decent one's should do it without a trip to the dealer.... If you have the access to one.
Ahh really? That's sucks. I was hoping to plug it in and go :p Do the scanners at the parts stores do that, or do you need a better scanner?
DANRICKARD
Oct 1, 2015 12:08 AM
