clunk in the rear?
clunk in the rear?
im about to take the balt over to the stealership tomorrow to get some bumper to bumper work done before 36k. first, im going to get my interior door handle re-wrapped in that shitty chrome tape thats peeling off and bubbling but for the second thing im kinda wondering how i should approach it.
so i have after market 18" rims and tires not the 15" steelies that came on it and i hear this clunk in the rear everytime i back out of my driveway. it sounds almost like a creak and it even happens sometimes on large bumps (speed bumps). first of all has anybody had this problem or know what it could possibly be? second, will the stealership fix it even tho i have oversized wheels, or should i switch the steelies back on before i go? lastly, what would my argument be if i did take it in with oversized wheels and they refuse to repair it?
woah long rant but any help would be appreciated!
thanx in advance
bump! 4 views? maybe i just had a crappy title...
thanx in advance
Last edited by 08ShowbaltLS; Jul 19, 2010 at 02:58 PM. Reason: Automerged Doublepost
I have a similar issue. I get a loud creaking from the right rear area when the body is subjected to twist (hard cornering or driving diagonally over my driveway curb). It sounds like it is in the right c pillar area (I have a sedan). I am sure it is some sort of suspension component or mounting point.
Any ideas guys?
Any ideas guys?
well the clunk I am sure is your exhaust, because it really can't possibly be anything else in the rear.. mine does it too, but only because my exhaust is hitting my axle beam.
I have the same noise on the passenger side. To me it sounds like the seat belt retractor in the B pillar maybe the C. It's hard to tell.
It sounds like metal hitting metal.
It's only when hitting a bump hard on the right side.
I can't figure out where it's coming from and it bugs me.
I had the dealer check it out when i had the oil changed and the PS recall done.
They tightened the heat shield for the fuel tank. But i still hear it just as loud.
Any ideas guys?
Any ideas guys?
thanx in advance
thanx in advance
put steelies on to avoid an arguement... if it is body flex as someone mentioned... check the tops of yoru doors and body for wearing. i have small paint spots worn off im assuming from body roll on my sedan... paint is worn down to steel now... you;'ll see rub marks on the top edge of your door near the center pillar and also on the body where the top of the door flushes up. it should be warranty.
Defiantly put your stock wheels on they can be ******. I have been declined transmission work on my saturn cause i had 17" rims on the car. They could find something else wrong with drivetrain/ suspension that you don't even know about and blame it on the rims.
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
