clutch difficult to engage
Old Mar 16, 2010 | 05:20 AM
ikeryder13's Avatar
And idk y LOL
Umm basically i am having a problem with my clutch pedal after i redline in 2nd to 3rd gear the pedal doesnt regain tension and i sort of have to wait for it to to get it into 4th gear.
Plus there is a fluid residue near my left side of my axle and clutch box
the clutch doesnt slip at all and this only happens every once in a while
I have a spec stg 2+ clutch with a Aamco lightweight flywheel
I think it might be my throw out bearing
How do i find out? if it is can i just change my bearing? Is there anything else i could do? is a lnf bearing compatable and is it a upgrade?
Old Mar 16, 2010 | 06:43 AM
zrated89's Avatar
unfortunately on this car we utilize a throwout/slave hydraulic combination unit, and if that your issue you are gonna have to have the trans pulled again because it sit right in the input shaft. i would hope thats what it is if i was you and not a damaged tranny itself
Old Mar 16, 2010 | 07:01 AM
fshizl's Avatar
hey eric, its carlos the sedan tc owner... lol
right now gm's got my car and they are rebuilding my transmission...
how does it feel when you have the problem... is it like the pedal is limp? does 4th grind if you try to get into it?
Old Mar 16, 2010 | 12:22 PM
ikeryder13's Avatar
Hey Carlos, it does feel limp and is very difficult to get into 4th....
Usually I have to wait for it to get some tension
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
