Clutch issue
Old Mar 8, 2011 | 08:57 PM
YoBaltSS's Avatar
Clutch issue
I was backing out from work this evening, when I pushed down on the clutch pedal, I heard something metal snap under my foot. I stopped and looked around and found a thin grey S shaped piece of medal on the floor. I'm not totally sure what it is. The top of it clearly looks like it snapped, but I can't see anything that it would connect too.
The clutch still works, engages fine, etc. But there is virtually no resistance to the clutch pedal now, it goes straight to the floor when I push it in. Again, the car is running fine and is driveable, aside from it being a bit of a pain to find first gear. Sooo.
Does anyone know what this is? Is it something that I can fix, or will I have to take it in? Am I doing more potential damage to the car/clutch by still driving on it?
I'll to take a picture of the piece when I get home, it's about as thick as hanger wire and probably isn't any longer than my finger.
Thanks guys.
Old Mar 8, 2011 | 08:59 PM
Red Sun's Avatar
i say take it in...my damn pedal squeaks 24/7 bro haha wd-40 is a savior though...
Old Mar 8, 2011 | 09:09 PM
YoBaltSS's Avatar
I hadn't even thought of that... My pedal squeaks all the time, but I can't honestly say it has since the thing popped off.
Old Mar 8, 2011 | 09:20 PM
Red Sun's Avatar
well wd40 helps for like a day..i need to buy some grease...so whats that with your first gear??
Old Mar 8, 2011 | 09:30 PM
YoBaltSS's Avatar
The clutch goes straight to the floor, no resistance when looking to shift. More than anything, I think my timing is just off, i'm not used to the loose pedal so I can't find my spot to shift. I'd like to get it fixed ideally, if it's expensive though and i'm not hurting the car anymore by driving it, I might just deal with it for now.
Old Mar 8, 2011 | 10:03 PM
Erod's Avatar
Moderator Alumni
sigh
MOVED
Old Mar 9, 2011 | 08:55 AM
Red Sun's Avatar
well i just though about something...going to the dealer is gonna be a pain in the ass.. i needed a fog light and the from lip and they wanted $680... wtf this isnt a mercedes its a chevy..but yeah just go to a mechanic. if he tells you youhe needs a new piece for the clutch go to good ole ebay
Old Mar 14, 2011 | 04:37 PM
Ion's Avatar
Ion
Don't worry about it. Its a spring for pedal feel. You probably can't keep your cruise control on though. The pedal has a tendency to fall to its pressure position (or whatever that is called) without the spring and the cruise control deactivates. Mine broke a couple months ago and I never replaced it.
Old Mar 18, 2011 | 08:07 PM
YoBaltSS's Avatar
My cruise control hasn't worked in months... It'll attempt to engage, flash real quickly, but nothing happens... It's all probably connected.
Old Mar 19, 2011 | 12:07 AM
Ion's Avatar
Ion
Nice. Mine doesn't work cuz my flywheel is junk and I can't drive my car at speed anyway. :-( Such is life.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Trav3480
Oct 1, 2015 08:17 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
